back glass options...
Old Oct 5, 2008 | 11:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by alchemist1
When you all talk about seals and such, does the window "kit" that Ford sells not include the seals. One would assume (bad word, I know) that seals are included, otherwise, why call it a "kit". How many seals are needed for these slider windows and which ones are you all talking about that are still available and which ones are obsolete and available from the places NumberDummy quotes? Thanks-
ps -
Yes, the Blue Ridge Parkway is one of the most beautiful drives in the USA. Figures that stretch near Boone is Fubard. Boone IMO is a lot like Asheville, NC. Beautiful Appalachian city that a few years ago was suffering in the tourism business and decided to opt in to the All-Inclusive City motif. You wouldn't believe what this entails, but let us just say they went and still go to great pains to get the weird and losers of the world to come stay there. Unbelievable. With the risk that I now say something politically incorrect, I have to stop now....but I wish I didn't.
The complete slider kit comes with everything, glass, seals, the whole tamale, including that el cheapo POS plastic window latch, that breaks when you look at it.
We attended the F100 SuperNats in Knoxville last May. After it ended, we drove the Blue Ridge Parkway (BRP) north from Asheville. Ran into several detours, finally exited at Boone. The main drag in that town looks like something one sees here...strip malls, Mickey D's and other assorted kitsch.
The Park Service sez the Gov't is dragging its feet (where's FDR when we need him?), and won't have the bridge and other road hazards repaired on the BRP for two more years.
In the past, we've driven the BRP (& Skyline Drive) round trip from Front Royal to Natural Bridge, round trip on the segment from Asheville to Cherokee.
Old Oct 5, 2008 | 02:33 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Ah, you missunderstand. The seals mentioned are to repair your old slider, if you decide to just replace the glass in your broken one.
D3TZ10420A28A.. Back Window Seal-Grey Vinyl. This seal is for the sliding part of the glass. goes vertically from the top to the bottom of the window, and seals the sliding section to the non-sliding section. Two required for each side.
D3TZ10422A68A... Back Window Glass Side Seal. I beleive this is the seal that seals the immovable glass to the frame.
Then the two horizontal run (Seals) that the sliding glass section moves along at the bottom and top, inside the channel.
Great news if you want to attempt to repair an old slider.
The kit as mentioned before has equivalant seals, and the frame and glass too.
Old Oct 7, 2008 | 01:28 PM
alchemist1's Avatar
alchemist1
Out of luck on the slider glass at Alan Vester Ford. Number Dummy: Although the Ford parts finder site says they have one, the guys in their part shop can't locate it. Thanks for helping me out anyway.
Other option of the glass shop in my town buying a piece of safety glass and cutting to size won't work either - they are not confident about being able to cut it.
Looks like a piece of Lexan may be the cheapest/easiest option.
Old Oct 7, 2008 | 02:21 PM
NumberDummy
They may not be able to cut tempered glass, but they most likely can cut laminated glass. Laminated is also safety glass.
Laminated safety glass is made up of two thin pieces of glass with a sheet of plastic sandwiched in between. Ford used it for decades, at least thru the 1970's.
According to the Ford dealer parts locator system, Alan Vester Ford shows that sliding rear window kit as of 10/06/2008...call them back, get the parts manager on the phone.
Some of today's partsguy's are so dumb, it wouldn't surprise me if they were looking in a drawer for that glass. I'm not kidding, some of these guys are clucks!
Most of today's partsmen are not really partsmen at all, they're computer certified techs.
Today, all these peeps gotta do, is type the VIN into the 'puter from the vehicle they are working on. ALL the part numbers come up, so there is no parts catalog needed.
This is another reason most of these clucks shine you on when you ask for older parts.
The VIN system doesn't work on anything prior to the late 1980's, so part numbers have to be looked up in catalogs.
Most of these clucks don't know diddly, and couldn't tell an older Ford truck from a Chebbie.
Old Oct 12, 2008 | 06:49 AM
alchemist1's Avatar
alchemist1
Nice idea - thanks for the tip, but a couple questions:
1. Presume you didn't use the more expensive Lexan - it doesn't seem to bend as well.
2. The factory glass is 0.190 inches, and you can get plexiglass in 0.250" cast thickness that is about 0.190 inches nominal (e.g. dried). Problem is, that thick a plexiglass doesn't flex and bend as well. I'm guessing you might have used the 0.080 inch stuff - its the thinnest that Lowes sells. Let me know which you used - probably doesn't matter, but I have a HD next to the Lowes. All Lowes had was the 0.250" and the 0.080", nothing in between. That 0.080 stuff looks like it'd bend right in, but also would have some 'slop' since it's not as thick as the original.
3. Last question - how did you cut it. I know you can cut plexiglass by scoring and snapping off, but that back glass is rounded and has non-square edges. Can you use a RotoZip on it (like a Dremel and cuts perpendicular to the material)? Or would you still have to use a scoring tool and carefully make angled and curved scores? I think you might be able to sand plexiglass on edges too?
Thanks-sorry for long message
Originally Posted by saleen065
I had one busted out and I made one from plexiglass. Cost me nothing to do. You can buy the plexiglass at Home Depot and cut it yourself. It bends just enough to go into the frame if you don't want to take the entire window out and it looks perfect.
Old Oct 12, 2008 | 06:52 AM
saleen065's Avatar
saleen065
PM sent on this repair. It was very easy and inexpensive to do.
Old Oct 12, 2008 | 10:03 AM
eglaisi's Avatar
eglaisi
I went to a swap meet yesterday and I saw an OEM NOS sliding back window for $60. I offered him $50 and I took it home. Still in the box!
Old Oct 12, 2008 | 11:53 AM
saleen065's Avatar
saleen065
Wow, awesome deal! I wish I could find deals like that.
Old Oct 12, 2008 | 05:51 PM
jcduerr's Avatar
jcduerr
i have both sliders(GLASS,LATCH AND TRACK) and drivers side stationary ( GLASS ONLY NO ALUMINUM ) pm me if needed will seperate for shipping plus what ever you think they are worth.
Florida Native 72
Jun 21, 2020 03:41 PM
90Ford73
May 5, 2017 07:21 PM
heldy
2009 - 2014 F150
23
Dec 5, 2016 10:01 PM
dynamic
Jul 10, 2012 02:30 AM
nothercrash
21
May 25, 2011 07:59 AM
