General Automotive Discussion
need help with 06 taurus
Old Oct 3, 2008 | 06:10 AM
dixiemudder04's Avatar
dixiemudder04
We have an 06 taurus with 47,XXX miles on it. And about a week ago the check charging system popped up on the display. I went to advance and had it checked. Battery is new/good, alt is good. Everything checked out ok. But its still coming on. What could be the problem? Could the belt have lost tension and causing that warning?
Old Oct 5, 2008 | 12:28 AM
dieselguy2008's Avatar
dieselguy2008
Do you hear any noise coming from the belt tensioner? Thats about the only way its gonna loose tension is if the bearings are gone or the internal spring is broke in it. Could be a bad ground on the alt. or your battery!
Bruker
Aug 20, 2012 01:03 PM
msm20032003
Crossovers
Jun 8, 2009 09:35 PM
Bruker
15
May 15, 2008 02:07 PM
JerNla
22
Apr 5, 2005 07:31 AM
3rdshiftzombie
38
Mar 30, 2005 11:34 AM
