'96 F350 PCM problem?
I have a '96 F350 7.3L 4X4 Crew Cab that cranks but won't start. I've done all the work on it since new except when I paid a dealer $400 to replace a crank sensor (!@#$$%!!!... never again!) The odometer now shows 350,000 and my pride just won't let me turn it over to a dealer and I can't find anyone else to work on it (and don't want to either.)
It was running fine then one day wouldn't start. Here's what I've done so far:
Checked the fuel system. It gets pressure to the fuel rails.
I planned to check the oil in the high pressure pump... but read on.
All the fuses and the diode are ok. All the relays around the engine compartment fuse box are ok. I plugged in my OBD II which powers up but won't communicate with the computer. I'm assuming I need a new PCM.
At other sites, e.g., Dieselman, I read that there is a PCM and an Injector Control Module. The electrical schematic in my Haynes manual shows the PCM but no injector module. I removed what I think is the PCM, an aluminum box measuring 6x8.5x2 inches that was attached to the inner fender panel adjacent to the engine compartment fuse box. Written on it is "IDM-100 SAEO
F6TF-12B599-AA PWB 4130
6E10-2
6FAA0"
Is this the PCM or the ICM? Is there even an ICM at all? I noticed there's another module behind the glove box very close to the OBD connector and wonder what it might be. I wonder if there's anything else that might be wrong besides a PCM failure. Any help would be appreciated.
6E10-2
6FAA0"
You came to the right place to avoid the high costs of a dealer.
The part you removed from the fender is the IDM. The PCM is bolted through the fire wall. Behind the parking brake. You will need to remove the driverside inner fender liner.
Does you cigar lighter work? PCM and lighter share the same power supply.
Do you get smoke out of the tail pipe when cranking?
Does the tach move while cranking?
6E10-2
6FAA0"
Is the check engine light on all the time ?...
I see the PCM now.
Fuse 22 is OK as is the PCM relay.
The glow plugs power up.
The lighter works.
The tach moves when cranking.
No smoke.
The wait to start light goes on but there is no check engine light.
I'm going to pull the PCM now and make sure it's getting power.
I talked with a guy at Actron and he said that their scanners might not work on this vehicle and of course he blames Ford. The packaging said it would work though so I'll try to take it back.
I found a PCM nearby for $220 so I'm gonna bet my money on it.
I checked the HPOP and there was no oil in it. So I filled it but still no start. How can I test to see if it is working?
When I turn the key on I get the "Wait to Start" light. When I crank it I get "Water in Fuel" "Engine Temp" and "Fuel Filter" lights but no "Check Engine". The diagram for "Diesel Warning Lamps Display" doesn't show a CEL but I do see one on the Instrument Cluster diagram but it's for gas. I could sure use a better diagram.
No evidence of water in the IDM.
I guess I could replace the IDM too. It would still be cheaper than having it towed to a shop, assuming that I don't eventually have to do that anyway.
