front coil springs
Old Sep 30, 2008 | 09:33 PM
mrwrench's Avatar
mrwrench
front coil springs
what's difference between 2wd and 4wd coil springs?
Old Oct 1, 2008 | 06:58 AM
F350-6's Avatar
F350-6
On our trucks, the 4wd uses leaf springs. The 2wd have coils.
Old Oct 1, 2008 | 07:42 AM
robinsonpowerstroke's Avatar
robinsonpowerstroke
Originally Posted by F350-6
On our trucks the 4wd uses leaf springs. The 2wd have coils.
And the leafs in the front are shot at about 125K.
Old Oct 1, 2008 | 07:44 AM
Ponyboychris's Avatar
Ponyboychris
What Chris said unless you are looking under an '05 and newer 4x4 Superduty. They came with coils.
Old Oct 1, 2008 | 08:42 AM
DCSpecial's Avatar
DCSpecial
I'll have to look at the coils on one of our 2wds later on when they get back to the shop and compare them to the ones on my 07 or 06.
Are you looking to swap coils?
Old Oct 1, 2008 | 10:29 AM
Izzy351's Avatar
Izzy351
Don't know about him, but I'm interested in lifting mine up a couple inches to level it. Tired of the door-stop look. I understand there are some heavier ones (for the ambulance package maybe??) that lift it a little. The other option as I understand it are spacers.
Sorry for the hijack, but I'm curious if one way is better than the other. And will I need new shocks for just a 2" lift in the front?? Any advice??
Old Oct 2, 2008 | 08:01 PM
Wieckster's Avatar
Wieckster
you can change your front leafs to the code x type and that will raise the front end about 2 in.
mine raised about that much now I need to FIND a set of 350 rear blocks to get my truck back to level any help anyone?
Old Oct 2, 2008 | 08:41 PM
DCSpecial's Avatar
DCSpecial
Custom coils would be the best way, IMO since you can get a nice progressive rate.
Any time you increase height on a 2wd you need to worry about keeping camber and caster within spec.
2wds are coil springs.
F-350 blocks...dealer. I have the part numbers if you need them.
Unrelated, how do you like that Boss plow?
Thinking of getting one for my 07 (used Westerns on my last two plow trucks).
Old Oct 2, 2008 | 09:15 PM
mrwrench's Avatar
mrwrench
if I lift 2 or 4 inche I will need to cahnge the radious arm brackets?
Old Oct 2, 2008 | 09:18 PM
DCSpecial's Avatar
DCSpecial
While we really don't mess with 2wds, I think 2" will be about max just doing a coil and being able to adjust camber and caster.
With a 4" you'd be better off being a suspension system that comes with everything that you need.
Old Oct 3, 2008 | 11:20 AM
indebt's Avatar
indebt
mine has a 6" lift, with the end result being about a 4" lift on a 4x4
Old Oct 3, 2008 | 04:17 PM
uliman's Avatar
uliman
I have a brand new F350 spacer and U-bolt set purchased from the dealer that I never got around to installing on my F250; now I have a F350. Just been sitting in my garage; I will sell it to you for my cost + shipping. It will be cheaper than buying straight from the dealer since I paid through FordDirectParts and they are part of the Ford Dealership here in Las Vegas but only sell through the internet at reduced prices - roughly 40-60% off dealer prices. They are now known as SilverState Ford Parts.
Old Oct 3, 2008 | 04:20 PM
uliman's Avatar
uliman
As an aside to this thread (hope it is not construed as a hijack) is it possible to use a 2wd coil setup on a 4wd truck? I would love to change over to coils on my 01 F350 3wd but all of the coil conversion kits lift the front end and I want to keep my lift at stock level. Anyone know about this? thanks
Old Oct 3, 2008 | 05:49 PM
Ponyboychris
If you find a '05 and up donor Superduty then you can steal parts for your '01.
Old Oct 3, 2008 | 10:34 PM
mrwrench's Avatar
mrwrench
where did u get the coils springs?
