Question?
Old Oct 2, 2008 | 12:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by ebk
F14HRBA7320
117 P F140 LZ4 A H9
BA7320 = The last 6 digits of the VIN is the Serial Number & the Numerical Sequence of Assembly.
117 = 117" Wheelbase.
P = Dark Nectarine Metallic.
F140 = F150 4WD 6,050 GVWR.
LZ4: LZ = Saddle & Tan all Vinyl with Saddle Appointments, Ranger XLT / 4 = Bench Seat.
A = New Process 435 4 Speed Transmission.
H9 = Ford 9" Rear Axle / 4.11-1 / Limited Slip / 3,750 lb. Rear Axle Capacity.
Old Oct 2, 2008 | 08:03 AM
tatonka04's Avatar
tatonka04
Sounds like a pretty cool truck!
Old Oct 2, 2008 | 08:07 AM
ebk's Avatar
ebk
Sweet! Yeah we are definitely getting this now. Prob needs a little motor work but oh well. Plans are to get rid of the bed on it and put a flat bed on there and clearance the front fenders a little bit. What is a good asking price on the beds?
Old Oct 2, 2008 | 09:56 AM
NOCO77's Avatar
NOCO77
A clean, rust-free short wide box that is pretty straight will easily pull $800 with some patience and the right marketing. (Sorry, Ben, but it's a short-box, you know - hard to find)
I've got over $800 into my box already, just with 3 minor rust repairs - the usual culprit areas, and have yet to start massaging out the other little dings. Ben's approximations would be dead on if it were a long-bed
Old Oct 2, 2008 | 05:12 PM
hpheltersnach's Avatar
hpheltersnach
Originally Posted by tatonka04
You're right Jolly Green. The T-18/T-19 had up and to the right for reverse. They look almost alike, except the pto port is on the passenger's side for the T-18 and on the driver's side for the T-19. Another difference between the two is that the T-19 has a synchronized 1st gear, as the T-18 doesn't.
The T-18 has reverse down and to the right just like the NP 435. You can tell the 435 from the T-18 because the top that bolts on the 435 is aluminum.
Old Oct 2, 2008 | 09:27 PM
ebk's Avatar
ebk
Thanks a lot guys. We will pulling off the bed for sure. I looked it over and other then surface rust it is pretty solid. I guess it will go up in the for sale section when we come to that.
