Sweet! Yeah we are definitely getting this now. Prob needs a little motor work but oh well. Plans are to get rid of the bed on it and put a flat bed on there and clearance the front fenders a little bit. What is a good asking price on the beds?
A clean, rust-free short wide box that is pretty straight will easily pull $800 with some patience and the right marketing. (Sorry, Ben, but it's a short-box, you know - hard to find)
I've got over $800 into my box already, just with 3 minor rust repairs - the usual culprit areas, and have yet to start massaging out the other little dings. Ben's approximations would be dead on if it were a long-bed
You're right Jolly Green. The T-18/T-19 had up and to the right for reverse. They look almost alike, except the pto port is on the passenger's side for the T-18 and on the driver's side for the T-19. Another difference between the two is that the T-19 has a synchronized 1st gear, as the T-18 doesn't.
The T-18 has reverse down and to the right just like the NP 435. You can tell the 435 from the T-18 because the top that bolts on the 435 is aluminum.
Thanks a lot guys. We will pulling off the bed for sure. I looked it over and other then surface rust it is pretty solid. I guess it will go up in the for sale section when we come to that.
