2003 6.0 problem.....
Old Sep 30, 2008 | 07:24 PM
go.avs's Avatar
go.avs
I've run in to something unexpected today, blew some fuses while screwing with third brake light wiring, replaced them, now when I turn the engine over it fires and immediately shuts off? Any ideas on where to start with this one?
Old Oct 1, 2008 | 12:07 AM
go.avs's Avatar
go.avs
nobody? Is it completely unrelated? I've rechecked all the fuses...no change. Is there a fuel pump relay or fuse somewhere other than the panel? I pulled the wiring harness plugs apart that are just in front of the fuel tank on the drivers side frame rail....but they are back together and tight. Still the same thing, cranks, fires and shuts off..... help?
Old Oct 1, 2008 | 07:13 PM
dcaddi2's Avatar
dcaddi2
You have a breaker on the passenger side foot area behind the plastic cover, but if it fires up and shuts off right away, I'm not sure it is the fuel pump. What I do know, that you have a relay for the PCM, maybe - I said maybe that what you looking for.
Get to the tech folder, pull your workshop manual - I'm sure you'll find wiring related troubleshoot information.....
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
