Clutch Problems
Old Sep 30, 2008 | 08:50 AM
dc2842002's Avatar
dc2842002
Clutch Problems
I think my trow-out bears is about gone. I figure while the tranny is out I will replace the clutch as well. Which clutch should I go with. I really don't want to replace the flywheel but I will if I get a better clutch at a good price.
Old Sep 30, 2008 | 08:56 AM
my79f's Avatar
my79f
valair clutches. those guys have some quality stock, and performance oriented clutches at great prices. alot of the guys over in the OBS forum are running valair clutches, and have not had any problems with them.
then there is also south bend clutches, which are going to be of the same quality as valair, but somewhat more expensive.
and then there is also luk clutches.
Old Sep 30, 2008 | 08:57 AM
F350-6's Avatar
F350-6
Southbend and Luk are the popular choices. Both should offer you a softer pedal. If you're planning on adding power later, you might look at Southbend since they have some upgraded clutches designed for higher hp. Also make sure you get the kevlar pilot bushing when you're in there changing things out.
Old Sep 30, 2008 | 10:36 AM
dc2842002's Avatar
dc2842002
I just looked at the Valair website. I think I'm going to go with one of their clutches. Either the organic stock replacement with HD hub or the Kevlar/Ceramic. The organis is rated higher than the output I ever expect from my truck but a Kevlar/Ceramic is a better towing clutch and lasts longer. (So they say)
Old Sep 30, 2008 | 11:23 AM
ggirten's Avatar
ggirten
We put a Southbend in my Son's truck. It was Con OFE - Using 1 Performance Organic & 1 Feramic Facing. It came with a new fly wheel. Very soft clutch, but hasn't tried to slip once.
Old Oct 12, 2008 | 04:45 PM
dc2842002's Avatar
dc2842002
Ok.... Still doing some research on which clutch I'm going with. The noises from the throw-out bearing are less often now but when they are there they are loud. I have also has some trouble with getting the tranny in gear a few times. I am thinking that there is a good possibility that the clutch fingers might be damaged.
I was thinking I would go witht he Valair clutch but they do not some with a flywheel and I have decided I should just do the flywheel too.
So my question is what is the favorite around here. The standard dual mass or upgrade to a single mass?
Old Oct 12, 2008 | 05:53 PM
dpwilson's Avatar
dpwilson
Favorite is gonna be the sb products. I think I will go ahead and give the valair a try. That is after I talk to the guy (Dan?) and get the scoop. I plan on doing this in a couple weeks.
I have never tried installing a clutch before...so I will wait for the Bro in law (mechanic) to get back from vacation to show me the ropes, hence the couple weeks.
According to there website smf is $287.
Old Oct 12, 2008 | 05:55 PM
dc2842002's Avatar
dc2842002
I have never done a clutch with the engine in the vehicle. My dad is going to come help me. He has a transmission jack that should makeit easier.
I thought about the valair but I haven't found one that comes with a flywheel
Old Oct 12, 2008 | 05:57 PM
dpwilson's Avatar
dpwilson
Decided which product?
Old Oct 12, 2008 | 06:01 PM
dc2842002's Avatar
dc2842002
not yet. still thinking about it. I will be out of town next weekend. so I have at least two weeks before I will be doing it.
Old Oct 13, 2008 | 02:22 AM
RubberDuck's Avatar
RubberDuck
Darin, if you have a clutch picked out from Valair that you like, call Dan and tell him Cody from Death Row Diesel sent you and he'll make the price a whole lot sweeter. Talk to him about your questions about the flywheel. He's a super cool guy to talk to, and I guarentee he'll answer all you questions.
Old Oct 13, 2008 | 06:18 AM
dc2842002's Avatar
dc2842002
I willl have to do that. Thanks
Old Oct 14, 2008 | 08:11 PM
dc2842002's Avatar
dc2842002
Does my '03 have the dual mass flywheel?
Old Oct 14, 2008 | 08:19 PM
Kwikkordead's Avatar
Kwikkordead
No. They are single.
Old Oct 14, 2008 | 08:21 PM
dc2842002's Avatar
dc2842002
That's what I was thinking and hoping. Thanks
alstang1
2004 - 2008 F150
Oct 10, 2017 05:13 PM
bphirt1
May 17, 2015 07:54 PM
hankviii
Feb 4, 2015 11:14 PM
jle70
1978 - 1996 Big Bronco
Dec 24, 2013 09:47 PM
JHoffman93
34
Jan 14, 2010 10:00 AM
