Oil Leaks
Old Sep 29, 2008 | 01:07 PM
cchildress's Avatar
cchildress
Oil Leaks
Ok well since my engine has been back together I have had multiple oil leaks. My hpop was pouring it like crazy yesterday and thanks to Cody at deathrow I got it fixed but still have oil comeing out in other places. What key points like to leak. I have replaced the rear main and turbo o-rings, but what else leaks that is notoriouse for it.I think there is oil comeing from around my oil filter to. Idk but it is driving me crazy...
Thanks, Cody
Old Sep 29, 2008 | 01:16 PM
Neal 97 250's Avatar
Neal 97 250
Are most of the leaks in the valley? I have had o-rings to go bad on the rail plugs on the side of the head. They also leak on the back of the head. X2 on the turbo o-rings.
You may need to clean it up a bit to locate the leaks.
Check the oil filter. I have hed them to leak as well.
Old Sep 29, 2008 | 01:22 PM
cchildress's Avatar
cchildress
I had it spot less Sprayed it down with super clean and washed it off when I worked to on the hpop and then it leaked again but called cody and fixed it but didnt wash it back off. I will today but looking at the back of the engine from under the truck both sides of the block are wet its not leaking to bad but just enough to **** me off. 7,000 miles on this engine and oil, oil, oil!!!! I replace some of the oil rail plugs but not all might be some more to look over. On the oil filter it is wet above the filter but runs down it. There is a bolt that sticks out and is wet but not sure what it so im afraid to tightin it a lil but I might just have to! Idk
strokin'_tatsch
65
Feb 6, 2023 09:36 AM
BadDogKuzz
26
Apr 20, 2018 05:01 PM
Cody Lee Von Elm
Jan 10, 2017 12:48 PM
Cody price
16
Apr 1, 2016 11:55 AM
Cody_1948
Apr 13, 2011 01:09 PM
