What is the Cody Test ???
Old Feb 20, 2016 | 10:08 AM
BadDogKuzz's Avatar
BadDogKuzz
I do recall hearing something about the Cody test to check for leaks in HPO system. I do not think I have a issue or should I say I hope not.
But I am going to replace the HPOP lines and I this would be a good time to do so.
I don't want to pressurize it the wrong way or actually damage something.
Also is the Cody Test just for checking for leaking injector O rings?
Old Feb 20, 2016 | 10:33 AM
scotttahoe's Avatar
scotttahoe
I'm not 100% sure but I think it's when you pour icy water onto the ICP.
Old Feb 20, 2016 | 10:42 AM
takotruckin's Avatar
takotruckin
This is the problem with calling stuff stupid irrelevant names after whoever posted it on the forum first....
You put air into the high oil pressure rail on the head and listen/look for leaks. You will see if there are leaking upper injector o-rings.
There is no way to hurt anything, you are only using up to 150 psi shop air pressure. Just watch for the oil coming out when you remove your air source.
It is more or less a waste of time if you don't have any problems. Any injector o ring that is leaking at 150 psi will more than likely have a starting problem already.
This thread a few posts down describes exactly what happens when you have an upper o ring leaking
https://www.ford-trucks.com/forums/1...-cranking.html
Old Feb 20, 2016 | 10:49 AM
scotttahoe's Avatar
scotttahoe
Well, Ed you had a better idea than I did. Lol
Old Feb 20, 2016 | 09:30 PM
BadDogKuzz's Avatar
BadDogKuzz
Thank you for clearing this up for me! But I will make a mental note to use this when I do run into an issue.
This proves you can teach an old dog new tricks. LOL To bad I have no real need to do this but it will come in handy some day. I just hope when the day comes that I will remember what to do. Dah..LOL
Old Feb 21, 2016 | 07:13 AM
Tugly's Avatar
Tugly
...like the "Hutch" mod? The boost leak detector is pretty straight forward for naming, but it still requires explanation to the newbies. While admitting I haven't really put my shoulder to a good name for this test - I was the twit that first coined the name after Cody's introduction of the test.
Since this is an annoyance... I'll make a few stabs at it, then I am anxious to see your contribution.
HPO rail...
...puff test
...leak test
...air test
...inflation test
Injector O-ring leak test
I suspect no matter what we name this one, people will still ask what it is, how it's done, and what the benefits are - just like the Hutch mod, the boost leak detector, the 50-cent mod, the 42-pin connector test, the red line mod, the zoodad mod, the harpoon mod, etc....
Old Feb 21, 2016 | 09:05 AM
takotruckin
HPO rail...
...puff test
...leak test
...air test
...inflation test
For the past 10 years that i have been doing this testing on no start 7.3's and 6.0's I have simply referred to it as air checking the HPO system for leaks.
Old Feb 21, 2016 | 09:17 AM
CampSpringsJohn's Avatar
CampSpringsJohn
As Tugly said, so many things with regards to the 7.3 that have been done over the years, naming it after a guy that mentions it on here, or on other diesel sites, just became a habit. Nothing wrong with it in my opinion.
Old Feb 21, 2016 | 09:47 AM
Pikachu's Avatar
Pikachu
Pressure test. That's really what it is anyhow.
Old Apr 16, 2018 | 01:31 AM
dieseldogtom's Avatar
dieseldogtom
The "OFFICIAL" tester that sells on the dieselsite.com
has instructions that say to use 15 p.s.i. to do this test.
CORRECTION: I see (we) are talking a HPOP pressure test here.
I was thinking of the OTHER boost leak testing that is for intake air & such.
You wouldn't want 150 there!
See how easy it is for to get confused
DDT
Old Apr 16, 2018 | 06:26 PM
pirschwagon's Avatar
pirschwagon
This test is not included in the Factory Service Manual. It is however referenced in the Manual. The attached is from the Technician Training Manual. That is the only place I have ever seen it.
File Type: pdf
Old Apr 16, 2018 | 06:52 PM
DieselDenny's Avatar
DieselDenny
Being born in this forum, and not knowing my own cousins names..............
When it comes down to the hutch, the cody and the fifty.....blah blah
I think it's quite a large step up to throw a disappointing shovel of dirt at the acronyms.
I quickly associate what a problem is and understand the acronyms we use. Pisses me off when someone has they're hair tied to tight in they're pony tail or has a "particular" problem with a label for a repair.
Denny
Old Apr 16, 2018 | 08:29 PM
dieseldogtom
Yeah, I'm not really all that excited about it but I sort of like being part of the (secret club) that knows all the code words when talking about the Diesel Mods. and all the other abbreviations associated with (our) engines. IPR, CPS, IPS, TPS, HPOP, IVS,.. It's kind of like when you are computer tech. illiterate and someone that knows all about it starts talking to you on the subject. It's like they are speaking another language!
The (Diesel Club Code) sort of gives you the appearance of knowing more than (you) probably do.
A similar thing that can happen if you sit around the hanger and talk with pilots. If you get to know some of the
(code talk) you might be able to actually understand or participate in the conversation.
Do you have your PPL? Got any endorsements? Looks like it's going to be IFR in about an hour. What's the missed approach procedure?... And ask any non pilot what it means when an aircraft "stalls" and I bet they will tell you the engine must have quit running , right?
Anyway, I still got to do the Hutch, The Harpoon & R7R some HPOP o-rings. Did the CCV Mod. & Resonator Delete.
Still waiting for someone to ask me what the "Georgia Overdrive Equipped " in my signature means. LOL DDT
Old Apr 17, 2018 | 03:09 PM
HKusp's Avatar
HKusp
Mine would start and run all day if it started out with cold oil. If I started it and got some heat in the oil, then shut it off, it was all over after that until the oil cooled enough to build that initial ICP.
Old Apr 18, 2018 | 06:55 AM
Tugly's Avatar
Tugly
Sheesh dude... you've been away a while. I'll assume you've been making ridiculous coin with your plow in the East coast's long winter.
