Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
is this a good tool kit?
Old Sep 28, 2008 | 01:36 PM
77f2504by4's Avatar
77f2504by4
KD Tools Master Tubing Service Kit - Model KDS41590 at Sears.com
i need to do some custom brake lines soon and i'm thinking of getting this kit. any one have it? recommend a better set?
Old Sep 28, 2008 | 01:38 PM
Ford_Six's Avatar
Ford_Six
Seems to be pretty decent, although I have never used a bender. Hand forming always worked well for me.
Old Sep 28, 2008 | 01:54 PM
77f2504by4's Avatar
77f2504by4
i already have a bender, but i need to do some custom work with weird sized fittings, and that requires the use of a double flaring tool.
i like to use benders to get in the ballpark of the shape needed then hand tweak them. when i try using no bender, i tend to kink the lines...
thanks for the quick reply!
Old Sep 29, 2008 | 01:53 PM
daveengelson's Avatar
daveengelson
Kit appears to have all the items you will need. Since you already have a tube bender, may want to consider getting a kit minus the benderl, although, I prefer having 2-3 different type benders on hand. Looks like you are familiar with bending brake and fuel lines but thought I would toss in couple article I came across may find helpful.
Bending Stainless Steel Tubing - Car Craft Magazine
Brake Line Basics - Tech Articles - Classic Trucks Magazine
Old Sep 29, 2008 | 09:52 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
I bought the Craftsman Double Flairing tool with the intention of using and returning it. It doesn't include the bender and cost the same $$ but it's American made... Changed my mind, this is a good tool that works. That's a lot more than I can say about the OTC one that I started with! I added a $.99 Harbor Freight lifetime carbide 45 degree countersink and a small machinist file to the kit and been double flairing ever since.
Old Sep 29, 2008 | 10:30 PM
77f2504by4's Avatar
77f2504by4
added links to my favorites!! Thanks alot of good info, now i actually know how to use a tubing bender properly! maybe now i wont screw up lines any more!!!
Old Sep 29, 2008 | 10:33 PM
77f2504by4's Avatar
77f2504by4
i was going to buy the craftsman one, untill i saw the kd tools one was 5 bucks more, and came with extra stuff! i ordered the kd tools set today, and cant wait to try it out!! years ago i had a break line blow out that had been rubbing, and like a fool i replaced the whole line, i wish i had a double flaring tool way back then!
Old Sep 30, 2008 | 12:41 AM
ford2go's Avatar
ford2go
Some really interesting comments on this thread. I've always been too hesitant to flare my own lines. The few times I've been faced with the issue, I bought standard length lines with the ends already flared.
Checked out the KD website, and they looked OK. However, I do wonder what you might look for in a flaring tool -- other than that it seems to be solidly made.
Two other comments -- and again, I haven't done any flaring myself ( yet)
1. The CC link mentions using the a KD flaring tool for stainless. The KD website specifically says that their tool is NOT for stainless
2. A former garage jockey (NOT a trained mechanic)I used to know said that trying to splice brake lines was a real PITA. Claimed that the old lines usually split when you tried to flare them.
I'd welcome any commnts on my comments
Old Sep 30, 2008 | 10:23 PM
Bern_F150_4x4
I'd be surprised if any affordable flaring tools will double flare stainless tube.
I can see a few reasons why old failed tubing would crack when flaring. was he double flaring? Double flaring will prevent cracking. Internal/external rust could be an issue too.
The prep of the tube is the key to a good double flair.
Old Oct 1, 2008 | 12:21 AM
Chaosracing's Avatar
Chaosracing
Looks like a good kit. I have flared many a fuel or brake line and never had a problem with the end splitting. But then I also try to get away from the problem area for the splice. I always use a bender to get it to the general shape, then hand bend the rest of the way to tweek it to where it should be. I bent a few tubes with out the bender and kinked them.
Old Oct 1, 2008 | 07:55 PM
rebocardo's Avatar
rebocardo
I have the earlier version of the KD kit. I usually have to use a wrench on the flare handle to get it squished down properly. I would look at a handle type flarer.
daveengelson
Garage & Workshop
21
Dec 6, 2015 06:49 PM
Solomon_Man
Mar 9, 2012 02:22 PM
Bern_F150_4x4
Garage & Workshop
Oct 21, 2011 09:46 PM
oldgoat49
Garage & Workshop
18
Jan 30, 2007 10:10 PM
06RANGER
1983 - 2012 Ranger & B-Series
15
May 10, 2006 12:27 AM
