Need some help gettin started.
first... welcome to the forum and FTE... you're just gonna love this place.... as for your question.....you're at a crossroads right now... decision time.
do you want to use your truck as a weekend/daily driver or are you beginning a restoration/rodsteration ??
if your intention is to drive it as soon as you can.... answer this...
is the truck running now ?? will it turn over
if the answer is yes... I'd do this
a: check the fuel source as mentioned... old trucks sitting for years with fuel in the tank have varnish in the tanks now and they need to be cleaned out... you can remove the tank, pour out the gunk (in an environmentally safe manner) and check the condition of the innerards of the tank...there are several ways to clean it... from a radiator shop steaming it out to Eastwood products... but basically if its not too bad I'd throw a chain or two in it... pour in a gallon of mineral spirits or laquer thinner and do the hokey-pokey with it under your arm... agitate it to loosen all the 'stuff' and rinse it out. a handfull of fuel filters is probably a good idea also... while you have the tank out... disconnect the fuel line from the fuel pump and blow the lines out with compressed air... a little laquer thinner blown thru it wouldn't hurt either... put all that back together, put enough fuel in the tank so the pickup will...put in a fresh filter... disconnect the fuel line at the carb and crank it over... if you get fuel out of the line... good for you ... hook the line to the carb and your fuel system is ready.. if not.... back through the system and find the problem... could be a busted diaphram in the fuel pump or a clogged line from pump to carb...
b. if it turned over I'll assume you have a decent battery... just for fun clean all the battery cable connections... scrape off that green stuff and check the ground at the frame...fresh shiny metal is a good thing at the connection points...
if it's turning over and not running...you know you have good fuel 'cause you just fixed that ... check the points/cap/rotor/plugs... clean them all and/or replace them as needed..probably plug wires also... if you're getting fire after that...good... if not track down your problem... fire at the plugs ?? voltage at the coil ?? is the coil firing ?? basic elec troubleshooting here... don't forget the timing
ok I'll assume you're also an ace mechanic and you've got her running like a brand new one.... my next step would be
c. brakes... check for fluid leaks at all four wheels...check the m/c for stop juice... take a test drive down the driveway to see if they will stop. If you come to a short smooth straight stop...good... if not ... find the problem... lots of old trucks have stuck wheel cylinders.. if it's pulling to one side, check the opposite side for a stuck cylinder...... when you get all four wheels working together... move on
d. Check transmission and rear end for lubricant...
e. back flush and fill the radiator with good antifreeze... check the thermostat(s). let it idle for a few minutes and watch the temp gauge...if it doesn't run hot.... good.... if it does.. find the obstruction/problem
while you're doing that...
f. check tires overall condition...lug nuts tight......????? wheels tight on spindles
g. check/correct brake lights... turn signals are on your left shoulder.
h. all ok ??? stick some tools in the truck, take a short trip... half way should be no further than you'd like to walk back home. Feel the truck moving and listen for problems.. vibrations and noises will tell you the next thing to fix...listen for brakes dragging... wheel bearings grinding.. clunking in drive line might be universal joints.... gears gnashing ?? it's a ford
as your confidence in your ride increases, your trip distance can increase
have fun...
now... if you want to go straight to restoration/rodding your truck without enjoying arm out the window time... that's another posting and several more crossroads.... decisions about how you plan on changing your life patterns will be involved.... you should be concerned with the 700 billion dollar bail out as it will have effects on your credit limit....
later
John
if the oil leak is bad enough... I wouldn't try driving it far. Had a friend years ago that had a '54 ford with bad rear seals... we'd put a dishpan under it when it parked to catch the oil and pour it back through... used nothing but used oil (drained from other vehicles at the service station) in it and it ran for years that way... what teenagers will do !!!
later
John
I have a oil leak in my F-2 that leaves a puddle every time I park it. I've replaced the oil pan gaskets, along with the lower bearing seals but it still left a puddle. I have surmised it's the upper rear bearing seal. The engine doesn't drip while parked, I've only noticed the puddle happens right after I've parked the truck so I think the oil runs down from the upper seal but settles back into pan once the engine is turned off. I'm not going to go through the hassle of yanking the engine just to replace the seal. I can live with a little oil leakage.
You might get lucky, do a little checking around, perhaps the oil is leaking from an oil galley plug or the oil pressure gauge, or something like that.
later
John
...and I thought I was driving a Cadillac
Bobby
