project & E-303 Cam advice
Old Feb 14, 2009 | 12:04 PM
lew52's Avatar
lew52
Originally Posted by Conanski
OK.. but what are you comparing it to?
To a 5.0 mustang..With holley heads intake e303.& other stuff When we race him we beat him out of the hole real good .. He catches up towardes the end. but cant beat us...The truck is strong out of the hole need everbit of 315-60-15 drag radials.... He has 15 more HP than us But we got a lot more tourq... So with his set up he dosnt make power till 3000...Where we make power right at the line... He is runing a 2400 stall .... Were runing stock converter.... The truck on the dynojet RW 240HP 300 tourq... That was with bent leafsprings 14deg pos pinion angle... We did not know at the time... So i guess its more his intake head set up that makes the diff ..???. Alot of pepole say the 302s have no low end .... Why do we... Lew
Old Feb 14, 2009 | 12:37 PM
Conanski's Avatar
Conanski
That's pretty good power numbers there, about what is expected from a 5.0, what's the rest of your combo.. gearing, curb weight? Are you using the stock truck intake?
Old Feb 14, 2009 | 01:16 PM
lew52's Avatar
lew52
Running edelbrock performer truck intake...61mm duel throtle body 80mm pro m mass air... long tube headers..dooe 351 heads 180-160..So on... Tru trac 456 gears...the last time the truck was weighed it was 4100....at the dump....scale... now i think its about 3900...no sure...waiting for the scale to open at PBIR its under constuction...
Old Feb 14, 2009 | 01:18 PM
lew52's Avatar
lew52
That should be 190-160 on the valves Mistake Lew
Old Feb 14, 2009 | 05:29 PM
Conanski's Avatar
Conanski
Running edelbrock performer truck intake... long tube headers..dooe 351 heads 180-160..So on... Tru trac 456 gears...the last time the truck was weighed it was 4100....
Guessing at what the Mustang has I'd say shorties and 3.73 gears, your intake and heads will produce quite a bit more low rpm TQ than the Holley topend, so even though the stang weighs less the holeshot goes to you. But you could still have even more TQ with a cam better suited to your combo, playing with desktop dyno I found 30ft lbs more with virtually no loss in peak HP with an off-the-shelf cam, a custom grind would certainly do even better.
The big point here is that your combo is much better suited to that motor and vehicle than his is, longtubes, that long runner intake, and the gears all factor into the SOTP dyno and produce what feels like quite a bit more TQ.
Old Feb 14, 2009 | 06:37 PM
restoringmy46's Avatar
restoringmy46
I talked to Comp Cam the other day. I have a stock 302 but am changing the intake and a 600 or 650 carb. They said a K-Kit Extreme Energy 262 Cam would be good with a stock converter. Conanski I see your running a comp cam also. What do you think about this comp cam. It makes power from 1500 rpm to 5500 or 6500 rpm. I want a cam that you can at least here. I believe I can get the "complete" cam kit for $377. Thanks Scott
Old Feb 14, 2009 | 09:06 PM
Conanski's Avatar
Conanski
These cams are nice.. the one I have produces a very broad powerband.. the motor just keeps on pulling all the way across the tach. Make sure you get a carb specific cam(110lsa), the one I have is EFI friendly and that compromises peak power some.. no need to do that if you don't have to.
Old Feb 14, 2009 | 11:35 PM
Blurry94's Avatar
Blurry94
What have your done for weight reduction?
Old Feb 15, 2009 | 04:20 AM
lew52's Avatar
lew52
How did you know that??? Right on the money..He has shorties & 373...I have anouther 5.0 block ready to be built should any thing happen to the motor we have now....May stroke that to a 347...when we do that i will check with you on cam advise...Thanks Lew
Old Feb 15, 2009 | 04:45 AM
lew52's Avatar
lew52
we saved weight on exhaust...got rid of everthing..went long tube headers no cats just 2 1/2 in duels to 44 flow masters & turn downs right after the cab...Removed front gas tank...& spare tire...removed rear bummper & install fiber glass roll pan..fiberglass hood...removed air pump & egr..removed center seat section...replace front bumper with fiberglass bumper from fast ford fiberglass...lighter wheels...a lot of little stuff we didnt need...... Lew
Old Feb 15, 2009 | 07:44 AM
393STROKER's Avatar
393STROKER
When I said I retarded the cam, I should have said advanced.Sorry ,workin` too many hrs.
Old Feb 15, 2009 | 09:29 PM
Blurry94's Avatar
Blurry94
I'd love to shed some pounds on mine but I can't seem to give up those creature comforts. I dumped the stock stainless exhaust and went with a 3 inch Pickrel system. I'm sure the supercharger and intercooler install made up for difference in the exhaust weight reduction.
I didn't know Brian/fastford was still making bumpers for these rigs.
Old Feb 16, 2009 | 05:12 AM
  #28
lew52's Avatar
lew52
As far as i know Brian is still making stuff..I know he does it himself... I got the bumper about 8 months ago...Real nice fits great...Like your truck....I really like the gen 1 s... So its supercharged...must run good !!!....Lew
Loganc95
17
Jun 22, 2024 03:56 PM
billyrayf150
Feb 13, 2016 11:50 AM
CCope94
Feb 16, 2015 01:16 PM
CaptainJack_7
Nov 1, 2014 08:42 AM
kylelovesmud
Mar 9, 2014 09:37 AM
