94 F150 5.0, Holley Systemmax intake/Mustang Throttle body???
I've got a 94 f150 5.0, it currently has long tubes and true duals with an off road x-pipe, E303 cam and matching valve springs, new pushrods and lifters, timing chains and gears. I'm basically looking for a good intake manifold, I've seen the Edlebrock and heard of people doing the Holley Systemmax upper intake swap, what're thoughts?
Thanks,
Logan
Thanks,
Logan
This cam would be much better suited for use in a truck than the E303. The stock heads do not flow much beyond .500" lift so you will be losing out a bit on the return for your dollar. But the low end will return with this cam.
The truck 5L EFI intake is a nice piece, I would keep it.
I forgot to mention that I've got the Gt40's off of an explorer too lol. Sorry, terrible at explaining what I have.
the letter cams do not have the torque range and power band needed to move such a large vehicle . the gt40 heads are a great improvement , the p heads are a pia, I have them currently and have a constant misfire on #4 because I cant keep a plug wire on it without it burning off. in the 96 5.8 I am running a comp 35-510-8 , with 1.7 roller rockers with a performer efi and the dual 61 mm t/b gt40p heads, shorty headers and the k& n intake setup , my truck is a 4x4 supercab short box with 3.73 gears and turning 305/65/16 lt's .
92302FREAK
02-14-2008 06:15 PM
