Front end noise at slow speed. What is it?
I have a 97 Expy 4x4 with just over 100,000 miles. Recently I started hearing a noise. It sounds a lot like I have a nail in a tire but the tires are fine. It sounds once every tire rotation and only can hear it at idle speed. If I barely step on the brakes, the sound goes away. I pulled the wheels the other day and turned axle by hand but no noise. Does anyone know what might be causing this noise?
You didn't say it was the front in your first post.
Either way there is a high spot on the rotor that is hitting for each revolution of the tire. If the noise was every other revolution of the tire then it would be a wheel bearing since those rotate at half the speed of the tire.
If you want to confirm that it is not a tire, rotate the fronts to the back one at a time and see if the noise moves with them.
Positive it is not the tires. Thats why the noise stops when I even just barely push on the brakes. I thought the same that taking the weight off might effected something. I may just have to deal with it. At least until I decide to change out the front pads. Then I might dig around a little bit more to see what it could be. I was just hoping something like this has happened to someone else that could tell me what it is exactly. Thats for the input ALLORO.
Dont think it is a rotor either. It brakes smooth as silk at all speeds. I just can figure out the "clunk" sound at every rotation and only at slow speeds. Like I say it sounds a lot like a sound of a nail or screw in a tire but that has been ruled out. Sound goes away with just the slightest pressure to the brake pedal. I might just have to live with it for now.
