Sponsored by: Auxito
coolant leak
Old Sep 27, 2008 | 02:12 PM
80f100302's Avatar
80f100302
coolant leak
99 F150 4.2L Leaking from Tube pressed into manifold, Front of engine. Any ideas on how to fix this? Thought about JB weld but have to take top intake off to reach it. Thanks in advance for any help!!
Old Sep 27, 2008 | 04:39 PM
steve(ill)'s Avatar
steve(ill)
i dont know what the tube looks like on the 4.2 , if it is rusted, your screwed. if it leaks at the press joint and metal is still good, i would try BARS stop leak. I use the slilver flake stuff and it seals small leaks in gaskets and radiator. use it a lot in old trucks and tractors. i dont like the brown, oily liquied stuff. makes the antifreeze look like crap.... i had a real problem with a flange gasket on the bottom of a 5.4 intake manifold (cross over water pipe). i ended up getting the "head gasket sealer" type of BARS leak. You drain the antifreeze, install clean water and the sealer. run and let it work for an hour, then drain and refill with antifreeze. that was 9 months ago- works great. i regular radiator sealer would not hold more than 3 weeks.
Old Sep 27, 2008 | 05:27 PM
80f100302's Avatar
80f100302
Thanks Steve. The pin hole leak is right above the flange where the tube is pressed into the manifold. I flushed the system and put in prestone sealer. Seems to have stoped for now. Need to drive it and find out if it holds.
Old Sep 27, 2008 | 07:04 PM
80f100302's Avatar
80f100302
Prestone stop leak did not hold. Still have steady stream!!!
Old Sep 29, 2008 | 08:29 PM
steve(ill)'s Avatar
steve(ill)
you might try the head gasket and block crack sealer. that stuff is mean if you follow the directions. it dont work in antifreeze, only water
Old Sep 29, 2008 | 08:35 PM
steve(ill)'s Avatar
steve(ill)
this is what i used when all else failed.. follow directions.
http://www.barsproducts.com/1100.htm
87thhunter
Oct 14, 2014 09:52 AM
BobS1958
Sep 21, 2014 10:33 AM
78_f150
Aug 19, 2012 01:54 PM
mrpatrick150
May 1, 2011 09:15 PM
WmP
Jun 24, 2004 05:06 PM
