distributor o ring leaking still
Old Nov 15, 2011 | 06:39 PM
78_f150's Avatar
78_f150
Been having a problem with the distributor leaking. originaly it was not leaking. I rebuilt the motor the o ring was brittle, replaced it and now it leaks.
I have tried several O rings, all same result. any suggestions?
Old Nov 16, 2011 | 03:39 PM
i-w's Avatar
i-w
Well my first thought is to use gasket sealer.
Or
Make sure your PCV is functioning and properly
Hooked up.
Possibly too much crank case pressure.
Old Nov 16, 2011 | 04:11 PM
OldStyle's Avatar
OldStyle
Rusty Roller
+1 on both of the above. My thoughts exactly.
Old Nov 16, 2011 | 07:56 PM
78_f150's Avatar
78_f150
Or
Hooked up.
replaced pcv twice, i think the first one was screwed up but i do have a working on on it now and it did help but it is still leaking.
I tried gasket sealer but it didnt really help
Old Nov 16, 2011 | 08:28 PM
i-w's Avatar
i-w
well make sure you use a hose from both valve cover vents and "T" them together and from the "T" to the Carb intake port. make sure they go to a good vacuum source.
i would use the copper high temp RTV on the O ring also. let it dry before running the truck.
Old Nov 16, 2011 | 08:33 PM
i-w's Avatar
i-w
get a gasket like this one. and double up if need be. or RTV it. it sits flat on the engine.
can you take a pic for me of where it is leaking and the o ring.
Fel-Pro Q70194 - Fel-Pro Distributor Base Gaskets - Overview - SummitRacing.com
Old Aug 16, 2012 | 01:22 PM
Txhighboy's Avatar
Txhighboy
I am new to this thread but have the same problem. I recently put a rebuilt 390 in my son's 73 F250 and have had a distributor gasket leak since putting it in. I put a new PCV on with the new motor.
- I put a new beveled gasket on the distributor to rule out the gasket and it still leaked
- I added copper RTV to build up the gasket around the intake and it still leaked
- I just bought another PCV but the existing was not stuck...we shall see
Any other ideas? This is becoming annoying since the engine is running great other wise.
Thanks in advance. TXHighboy
Old Aug 16, 2012 | 02:01 PM
hivoltj's Avatar
hivoltj
You sure the front if the intake isn't leaking down into the distributor hole? It's very strange for you to have a leak there. I wouldn't use RTV unless you never want to adjust timing again!
Old Aug 16, 2012 | 05:26 PM
Txhighboy's Avatar
Txhighboy
Definitely seeping from intake hole for the distributor. Other than the PCV, would a faulty breather cap on the valve cover make a big difference to the pressure? Will send picture tomorrow when my son comes over. thanks
Old Aug 16, 2012 | 05:32 PM
hivoltj's Avatar
hivoltj
If either of you guys had a crankcase vent problem it would be gushing from the front and rear mains, oil pan gasket and blowing the dipstick out before it caused a leak at the distributor.
Old Aug 16, 2012 | 10:51 PM
J ballan's Avatar
J ballan
I would double check the intake gaskets.
Old Aug 18, 2012 | 10:48 PM
Txhighboy's Avatar
Txhighboy
Well I found my problem. The engine was rebuilt by a friend and someone put a oil breather cap on the left valve cover instead of the matching PCV. I ended putting a T off the vacuum on the carburetor, installed the matching PCV and connected it to the T inlet and BINGO...no oil leak! Both sides have a good solid vacuum with a PCV and this is venting the crankcase properly. Hope this helps the next guy. BTW, I found many threads on google to other sites that listed distributor leaks. Good luck!
Old Aug 19, 2012 | 05:06 AM
bamaf150's Avatar
bamaf150
So you are pulling vacuum from both valve covers? Wouldnt that create a vacuum inside the crankcase as opposed to just ventilating the crankcase; ie instead of pushing oil out past the rear main like you might with no pcv you might draw air inside the crankcase from there?
Old Aug 19, 2012 | 12:12 PM
kenny nunez's Avatar
kenny nunez
crankcase vacuum
2 things I have seen from pulling a negative pressure on a crankcase,
You may experience a "back fire" on decelleration or if the breather hole is plugged on the fuel pump the diaphram will collapse and the pump stops working. I know this sounds weird but it can happen. Kenny
Old Aug 19, 2012 | 01:54 PM
bamaf150's Avatar
bamaf150
Thats the kind of stuff I was wondering about.
mgargiullo
15
Oct 11, 2014 06:55 PM
78_f150
19
Oct 17, 2011 11:03 PM
VirginiaWiFinder
Dec 11, 2006 08:48 PM
colaking
Oct 22, 2004 03:48 AM
