Hot Tranny?
Old Oct 23, 2008 | 10:25 AM
  #31
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by liv
What does ford use for the oil pressure/oil temp and so on, and are they suitable to use as a reliable gauge?
You cannot tap into the trans temp sensor for an aftermarket gauge. If you try neither the gauge nor the PCM will work right. What you can do is use a tool that can read the OBDII data stream. The trans temp is there. Engine temps are there, too.
I understand the oil pressure sensor is an on/off sensor. It says there is no oil pressure below a certain (low) pressure, and says everything is fine if the pressure is above that.
Usually the factory sensor is within about 10F of the temperature at the test port. It can be higher or lower depending on conditions.
Old Oct 23, 2008 | 08:54 PM
  #32
liv's Avatar
liv
Thats not what I was asking. I was trying to figure out what ford used for sensors for the various parameters. I have a dashdaq coming I was just wondering what gauges could be considered "reliable" via the computer.
Old Oct 23, 2008 | 11:26 PM
  #33
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
Mark,
Thanks again for the reply...it is a good thing to have a reliable source of info such as yourself on this forum...many thanks.
Old Oct 23, 2008 | 11:48 PM
  #34
pipewelder71's Avatar
pipewelder71
Wow, I didn't think this thread was going to last long, but there's alot of great information.
I just found out that my head gaskets are wasted and my EGR cooler is gone. I found a dealership that is going to install my studs and a block off plate to the EGR cooler. That should end my problems in the future.
Anything else I need to do to bulletproof this truck while the cab is coming off?
Thanks
Old Oct 24, 2008 | 09:35 AM
  #35
Mark Kovalsky
All of the temperature sensors are very relaible and very accurate.
Old Apr 22, 2010 | 09:21 PM
  #36
chromedom's Avatar
chromedom
Veteran: Navy
Originally Posted by Kep4
After installing a Mag-Hytec pan on mine I've seen no difference on the ISSPRO trans gauge while towing up the Grapevine grade.
Anybody want to buy a Mag-Hytec pan in great condition?
I've seen a slight lowering of temps after installing a Dieselsite remote trans filter outside of the frame rail on the passenger side, though my measurements are not scientific and may just be wishful thinking. I installed it for the extra filtration with no expectation of any temperature differences.
I've never seen the trans temp on mine above 220, and only touched 220 on a 100+ August day towing 30 to 50 mph up a steep, winding side road bypassing the Grapevine.
Hi,
Just installed a dieselsite external trans filter and got my trans up to 160 on the freeway but never above 170. cooled down to 158 after leaving the xway. I put my hand on the filter expecting to feel it hot but it was actually cold????? Outside temp is 50 deg and the run lasted about 45 min. Is the cooler that good or is there another problem?
The Dieselsite tech said that it was normal and if I was still concerned pull the return line off and start the engine. Said it will fill a qt in15 sec. I really don't want to do this I just want to see what is normal,
Thanks
Gage2502
Apr 23, 2012 08:26 PM
WestxSRT10
Nov 14, 2008 05:15 PM
white Buffalo
Feb 19, 2007 07:00 AM
BigDawg54
Nov 17, 2003 07:42 AM
Fishin-Technician
Apr 17, 2003 12:01 PM
