351 flywheel
Old Sep 26, 2008 | 11:59 AM
oldranger6869's Avatar
oldranger6869
351 flywheel
I am going to put a 351w in a 1970 F-100 Ranger. I need a flywheel, and will probably seek one out in a junk yard. The 351 is out of a '73 galaxy. does it matter what year flywheel I buy?
Old Sep 26, 2008 | 01:39 PM
mcdobson's Avatar
mcdobson
Looks like 81-85 Bronco and 81-93 F150 used the same flywheel behind the 351w. Not a whole lot of vehicles came with a 351w and a standard trans.(I am assuming your using a standard trans). Also the the 80-81 Bronco and 80 F150 with a 302 used the same flywheel. Pioneer #FW113 or Ford # E8TZ-6375-C.
Happy hunting
Old Sep 26, 2008 | 03:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You need a flywheel and the engine is from a 1973 Galaxie (LTD).
No 351W Galaxie/LTD came with a manual transmission, so do you need a M/T flywheel or a A/T flexplate?
Old Sep 26, 2008 | 10:10 PM
mcdobson's Avatar
mcdobson
Thats my guess as to why he needs a flywheel to fit it.
Old Sep 27, 2008 | 10:46 PM
oldranger6869
Flywheel
The motor is going into a '70 pickup with a three on the tree. I need a flywheel not a flexplate.
Old Sep 28, 2008 | 01:55 AM
NumberDummy
Since the 1975/78 Econolines used the same 351W block as the 1973/78 Galaxies did, and were available with "3 on the tree" that's the flywheel I look for.
D7TZ6375C .. Flywheel-164 Tooth Ring Gear / Marked: C7TE-A or D7TE-GA / Obsolete.
Used on the following: 1973 Mustang & 1973/74 Torino 351C 4V / 1966/77 Bronco 302 / 1975/77 Econoline 351W (1978 and later used a different flywheel).
Old Feb 18, 2009 | 12:33 PM
Windsor 351's Avatar
Windsor 351
i have three of them flywheels in my barn one was just turned came off a 72 351W but any flywheel with the sandard starter (NOT HIGH Tourqe) will work so any thing from 1970 Stright 6 302 or 351 up to 1992 should work for what you need just make sure you dont use the clutch and pressure plate buy the one for that year if you dont already have it
jtapal
May 15, 2016 01:17 AM
4604wd4sp
West Virginia Chapter
Dec 29, 2013 08:47 PM
meredithbagged
Jul 28, 2005 09:46 AM
farlight7
20
Nov 1, 2003 06:39 AM
351coupe
Oct 2, 2002 01:17 AM
