Is it the Right Flywheel?
Old Oct 22, 2003 | 08:18 AM
farlight7's Avatar
farlight7
Question Is it the Right Flywheel?
After completing a engine swap (from 302 to 351w), there was a noticible engine vibration.
My mechanic thinks the Remanufactured Flywheel I bought might not be balanced properly. (The 351w came out of an automatic).
The main bearings are bad, so I'll be pulling the engine again and putting in a crankshaft kit.
While the engine is out, is there a sure way to check the balance of the flywheel? How much should it weight, are there numbers to look for on the flywheel, et c.???
Thanks,
Farlight7
Old Oct 22, 2003 | 08:30 AM
jwtaylor's Avatar
jwtaylor
The 351 uses a 28oz balance flywheel/flexplate. So if you reused or ordered one for the 302 then the vibration is more likely than not the flexplate somthing like 82 down used a 28 oz and 82 or so up used a 50 oz, hope this helps some. later
Old Oct 22, 2003 | 08:36 AM
farlight7's Avatar
farlight7
I ordered the Flywheel for the 1990 351w. I only hope that's what actually came in the box. Anyway to check to make sure?
Do the remanufacturers check the incoming cores, and confirm they are labeled correctly?
Farlight7
Old Oct 22, 2003 | 08:51 AM
jwtaylor's Avatar
jwtaylor
Is there a part number on it? If so call them back and see if you can reference the number if it doesn't have a weight stamped on it somewhere. Worse case scenario I would think a tranny shop could double check it for you. Did you install a pilot bearing?
Old Oct 22, 2003 | 10:23 AM
farlight7's Avatar
farlight7
Installed new pilot bearing, clutch assembly, throwout bearing.
Old Oct 22, 2003 | 11:54 AM
jwtaylor's Avatar
jwtaylor
Given you didn't metion any vibration before the swap I would say that the flywheel would be a good place to start as you mentioned. Where you able to find a number?
Old Oct 22, 2003 | 06:07 PM
farlight7's Avatar
farlight7
Not yet, engine is still in the truck. I be pulling it this weekend.
Old Oct 22, 2003 | 06:24 PM
jwtaylor's Avatar
jwtaylor
let us know what you find. later
Old Oct 22, 2003 | 10:10 PM
ford190082's Avatar
ford190082
i am not a pro at this or a mechanic. but i swapped a 300 6cyl standard, to a 351 standard that was an automatic, now my point being is that the flywheel measured the same and bolted up the same and i was getting ready to bolt the 351w in that evening when a mechanic friend told me that i would get vibration and tear out the bottom end within a week , he mentioned that all flywheels are weighted differently for all engines, and thanks to his advice i didn't regret spending the 350.00 bucks, unfortunately i found out that getting a flywheel for a 351 w is not easy but not hard to find but expensive.
like i said though i am not a pro or a mechanic but hope this helps you make the decision
Old Oct 23, 2003 | 07:20 AM
71swissaqua's Avatar
71swissaqua
If you can't cross reference the numbers take a tape measure and measure the actual weight on the flywheel. Post it back on here and I'll measure the weight on a flexplate with a 50 oz weight on it. If you put the 2 side by side it is very noticeable which is the 50 oz
Clint
Old Oct 23, 2003 | 11:35 AM
Kemicalburns's Avatar
Kemicalburns
im swapping my tired 302 for a 351 . my tranny is an AOD. So I found that a crownvictoria late 80's came with a 351/AOD. so got one from a wrecking yard for $50. the motor is going in this weekend.
late
Old Oct 23, 2003 | 01:50 PM
farlight7's Avatar
farlight7
Will do, hopefully I get the engine out this weekend. But I want to get this vibration/flywheel problem figured out. Don't want to ruin a brand new crank and bearings.
Any chance engine vibration could be caused by the harmonic balancer??
Or could the crank be so worn that its wobbling around??
Auto to Auto: that's the way to go. I got my engine from a van with auto, but in went into my truck with 5 speed manual.
Old Oct 23, 2003 | 02:47 PM
Kemicalburns
could be the balancer to
Old Oct 31, 2003 | 12:54 PM
farlight7's Avatar
farlight7
Finally got the engine out of the truck. Did it by myself, 3 1/2 hours from truch to engine stand. Only dropped it once : ).
Not really dropped, just let the cherry picker down too fast.
The flywheel info:
Casting numbers are E8TR-AA
5 7D3
the dimensions of the counter weight are 1 1/2 inches high
5 1/2 inches at the widest and 3 3/4 inches at the narrow.
Thanks for all the help.
Farlight7
Old Oct 31, 2003 | 02:39 PM
71swissaqua
O.K., went out and measured the flexplate that came with my AOD. It is out of a late modle Mustand so it should be 50 oz. i know side by side with the one I bought for my 351W there was a noticable difference between the sizes of the weights,
Measuring this one at the top of the radius is 4 1/4" bottom of radius is 4" it is 15/16" wide and 1/2 thick. Does not sound anywhere as large as the one you have so I am at a loss.
WWhen I did my AOD swap I went to Autozone and bought a reman. flexplate for a 1990 F150 5.8 AOD. It might be worth it too you to at least take yours to a parts house and compare it too one out of a 90 F150 5.8 AOD. Mine was'nt but $45.
Hope this helps
Clint
