wont shift into 4x4
Old Sep 25, 2008 | 05:50 PM
maguyver's Avatar
maguyver
wont shift into 4x4
Help! 2004 f-150 wont go into 4wd I was having problem with solenoid so I replaced solenoid. still had grinding noise passenger side I replaced actuators on both sides checked vacume all is well (so I thought) front weels freewheel no grinding turn switch to 4wd high hubs will not lock in check solenoid i still have vacume when there should not be any turn to 4wd low tranny shifts into low gear still no hubs locked in. does anybody have any more sugestions!
Old Sep 25, 2008 | 06:00 PM
mattd17's Avatar
mattd17
since the actuating solenoid is brand new, it should work (not always, but lets hope it does). my next step would be to check the wiring that controls the soleniod, and make sure that its getting power. is there a fuse for the switch somewhere? i havent looked into that, but that would be my first step.
Old Sep 25, 2008 | 08:33 PM
maguyver's Avatar
maguyver
wont shift into 4x4
I checked all fuses all good.
I have voltage to one side of the solenoid constant 12+
volts but the control side of the soleoid is not getting voltage and I cant find out where this is supposed to be comeing from
Old Sep 26, 2008 | 04:48 PM
Oldguy4's Avatar
Oldguy4
If one wire has 12 volts the other wire will need to get to ground. Does the 4wd switch provide the battery or ground? I don't know, just asking.
Old Sep 26, 2008 | 06:18 PM
maguyver's Avatar
maguyver
I guess that is my question also!
does anybody know where control signal comes from
any help would be appreciated
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
Rus01
Oct 20, 2016 11:01 PM
strat875
Modular V8 (4.6L, 5.4L)
Nov 28, 2015 10:12 PM
John TN
1983 - 2012 Ranger & B-Series
Dec 1, 2009 03:05 PM
m350
1997 - 2003 F150
Feb 2, 2008 12:40 PM
