I have a 2008 F350 and my automatic hubs won't work, also when I turn the AC on there is heat coming out of one side of the vents.
Im assuming this is a vacume leak somewhere but my vacume pump doesn't run steady? I thought if there is a vacume leak then your pump should run steady??
Mine was fixed by the dealer as part of another issue that was covered and they said caused it, but I was able to find a couple youtube vids on it in case I had to do it. When I got the truck back after the other repairs, my son was with me and it was hot so I turned on the ac and the drivers side was cool but the pass side was blowing warm. had the dual system in that one too.
I had this same issue. The vacuum line had melted on the right side as it went frown next to the exhaust. The A/C would shoot up on the windshield when not working properly. Replaced the line and everything works great now. Good luck
