Sponsored by: Innova
Remote Start/Alarm Installation
Old Sep 25, 2008 | 04:59 PM
Imondi's Avatar
Imondi
Alright, there has got to be a few people out there who have done these. I am installing a remote start to a 2000 F350. Everything seems to work except the remote start function. The truck starts up fine, runs for about 8-10 seconds, and then shuts down. It then kicks itself back on, restarts the truck for 8-10 seconds, shuts down, ect. It does this about 5 times and then gives up.
You guys got any ideas?
Old Sep 25, 2008 | 07:15 PM
Zip's Avatar
Zip
I am by no means an expert but had a similar problem with my wifes car. It was a used car so I didn't do the install. The problem was the wire for the tack was not making good contact with the wire it was spliced to. It would start then stop then do it again.
Probably not your problem but I guess something to keep in mind.
Old Sep 25, 2008 | 07:59 PM
ReAX's Avatar
ReAX
Tach sense is a good place to start. How are you sensing? Voltage sense or tach, and what is driving it?
Old Sep 25, 2008 | 09:14 PM
Imondi's Avatar
Imondi
Right now, I am tapped into the white/pink tach wire behind the dash. I have tried simply unplugging it, as well as grounding it, just to see if it worked and all three gave the same result.
Old Sep 26, 2008 | 12:44 AM
ReAX's Avatar
ReAX
Is the brain capable of voltage sense and programmed for a clean tach signal?
Old Sep 26, 2008 | 08:18 AM
Imondi's Avatar
Imondi
I am relatively new to this so here is what the directions stay:
"Connect to the vehicle's tach wire. The correct wire shows between 1V to 6V (AC) and fluxtuates with the idle of the engine when testing.
The wire has the same function with the high-voltage sensing input, so it is an alternative solution when voltage sensing input does not supply satisfactory operation."
Now, the truck will crank for a few seconds, but it will not start with the tach wire plugged in. With it unplugged, however, it is programmed to crank for six seconds. It then starts, runs, and shuts off like it has been.
I really appreciate the help from you guys!!
Old Sep 26, 2008 | 01:52 PM
ReAX's Avatar
ReAX
It sounds like you have two wires for same function, either voltage sense or tach, both can let the module know if the motor is running. While the voltage method is simple, a tach signal is more accurate. Did you test the tach signal? When I was in school, we used either a coil or injector for tach pick up, both of these locations give you the VAC and can be easy to access if your tach wire doesn't test out correctly.
Curt's05
Apr 1, 2015 11:49 AM
Curt's05
Jun 13, 2014 11:06 AM
Hayes9000
Dec 17, 2009 08:34 PM
Ford Fx4
2004 - 2008 F150
Dec 18, 2007 07:44 AM
Matt M, PA
Jan 26, 2005 12:51 PM
