Offroad & 4x4
front end 4x4 issues
Old Sep 23, 2008 | 02:10 PM
slammds15's Avatar
slammds15
I recently purchased a 2005 F250 super duty and the four wheel drive seems to work intermitantly. if i lock the hubs it works, I turned them to automatic and it worked for a while. Now im not too sure how this system works, but I know that that it applies vacum in both steering knuckles when you select 4x4. When I select four wheel drive on the dash within 10-15 seconds my heater goes to defrost and remains there until I put it back into 2wd. Hence a large vacum leak. Do the automatic hubs operate on vacum? or is it something different? if it is what does it actuate?
<!-- / message --><!-- sig -->
Old Sep 23, 2008 | 03:08 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
Auto hubs are vacuumed controlled, i believe... I also think your on the right track with a vacuum leak or something lines plugged up some where...
Old Sep 23, 2008 | 03:14 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Yes they're vacum controlled hubs.
If it was just the hubs not locking I would say you've got a leak in those lines, but since you've a second problem I would bet it might be bigger or somewhere else in the system. Check in the SD forum about the air only going through the the defroster, I'm pretty sure theres a bunch of threads about the specific vacuum leak that can cause that, and it might be a good starting place.
Old Sep 23, 2008 | 04:16 PM
bigrey6306's Avatar
bigrey6306
there are a bunch of threads on this problem in the superduty forum
sounds like a vacuum leak on your hubs, which happens to almost every superduty
I dont even use the auto hubs, I manually lock em, dont want to be in some mud and not have 4wd
Old Sep 23, 2008 | 07:05 PM
slammds15's Avatar
slammds15
The vacum solenoid that is suppose to realease vacum is working intermitanly. Thats one problem, the second is when I try to pull some vacum on the left front knuckle I can't. so I suppose a seal and solenoid should fix it... for now. the vacum pump will only pull 15 inches, is that sufficient?
Old Sep 24, 2008 | 01:40 AM
75F350's Avatar
75F350
Your system is apulse vacuum system. It does not require a constant vacuum.
If this was the case, the hubs would disengage if the vehicle were to be shut off. Imagine running in some mud, and stopping for a rest, and turning your truck off, and having your hubs disengage. Bad things, but this is not intended to happen because the huns are pulse activated.
Regardless, the ESOF system is junk at best, and anyone using this system with any type of reliabilty has been plain lucky.
Ditch the entire system for manual hubs, and block the vacuum system. Your climate control will work, and you will have a more reliable 4wd system.
Might consider the Dynatrac system real soon, because the next worse thing on the Sd trucks after the ESOF, is the dumb unit bearings.
What were they thinking?
Old Sep 24, 2008 | 02:12 AM
rebocardo's Avatar
rebocardo
Ford automatic hubs stunk in the 80s/mid 90s, Ford found a way to make them even worse, even worse then that, they put them on trucks that should not have them and put "hubs" on their abortion Dana 50.
I expect to find hub bearings on AWD vehicles like my Aerostar, non a light 1 ton truck
chuck7300
Jul 18, 2014 05:07 AM
Taylormade1
1997 - 2003 F150
Nov 6, 2012 09:46 AM
strokingbeast
Dec 15, 2010 09:33 PM
STXFitz
1983 - 2012 Ranger & B-Series
Feb 2, 2009 09:19 AM
freedom52
Sep 14, 2006 10:14 AM
