Sponsored by: Real Truck
Starting problems
Old Nov 13, 2013 | 05:20 PM
Sands77's Avatar
Sands77
Starting problems
Hey guys I need some help. I have a 2005 ford f250 super duty 5.4L the problem am having is the other day I took the truck out the yard an parked it across the street. 2 hours later I went back to move it it would not start the engine just kept rolling over I did this for about an hour it still refused to start. 2 days later I tried it again it started without any problems. I put a code reader on it it said P0453 fuel tank pressure sensor. If that is going bad would that cause that problem or would it be another cause.
Old Nov 13, 2013 | 05:31 PM
redford's Avatar
redford
FTE Leadership Emeritus
Hello Sands77. Welcome to FTE!
Here is a video on the P0453 error code, causes and how to troubleshoot the sensor.
Having posted that, I am having a hard time coming up with that error code causing your truck not to start. But hey, I could be wrong.
Old Nov 13, 2013 | 05:39 PM
Bigpipes 35's Avatar
Bigpipes 35
If It does it again you need to do one of two things, first listen for the fuel pump to cycle when you turn on the key or get a fuel pressure gauge and check what your fuel pressure is. With that being said I think you are looking at a fuel pump issue..
Custer28
Apr 11, 2018 03:10 PM
Charlie19
Jun 24, 2015 09:53 PM
dirtmonkey11
Jan 21, 2010 10:06 AM
brett12396f150
Aug 25, 2009 12:05 PM
cgarym7
Mar 9, 2009 02:02 AM
