Upper Ball joint replacement
Old Sep 23, 2008 | 09:15 AM
maceslin's Avatar
maceslin
I have the same question that was asked in 2006 on this forum but nevr answered.
My 02 Explorer with 165K on it has uneven wear pattern on tire and upper ball joint boot is all torn up so I suspect that the upper ball joint requires replacement. My CD shows that the entire control arm must be replaced while Advance AutoParts shows several replacemnt ball joints available. When looking at the control arm I don't see a snap ring or tack weld holding the ball joint in place. How is this ball joint held in place?
Has anyone just replaced the upper ball joint without replacing the entire control arm ($170 vs $40).
Thanks
Dave
Old Sep 23, 2008 | 09:58 AM
aquanaut20's Avatar
aquanaut20
The OEM one piece assembly has to be changed out the first time, subsequent repairs are piecemeal.
Old Sep 23, 2008 | 11:47 AM
maceslin's Avatar
maceslin
I assume that you are talking a non OEM replacement for the controlarm assembly
Old Sep 23, 2008 | 07:17 PM
steve(ill)'s Avatar
steve(ill)
if you buy something like MOOG parts, then the ball joint can be changed out by itself the second time, since you have the aftermarket arm.---- alwlays expect the lower ball joint first. if they ahve been changed out already at 100K, then the uppers might be the problem. you can have it jacked up and checked by someone who knows how.
Old Jan 22, 2009 | 10:11 AM
bradcdavis00's Avatar
bradcdavis00
I think this thread answers my question. Thanks!
Just to be sure...
My 02 Explorer 4x4 has the OEM control arm and ball joint.
I will have to replace the arm/joint assembly this first time with a MOOG or equivalent. Right?
Next time I will be able to just replace the joint, right?
BTW, the joints are fine, the crummy boots just cracked away.
Old Jan 22, 2009 | 08:55 PM
steve(ill)'s Avatar
steve(ill)
you are correct.
briangelc
Jan 4, 2020 08:37 AM
07250psd
28
Aug 28, 2016 12:27 PM
eallanboggs
Feb 23, 2008 09:41 PM
oldstylefseries
1997 - 2003 F150
Sep 26, 2006 09:38 AM
bassaway
1983 - 2012 Ranger & B-Series
May 23, 2005 11:00 AM
