AIH delete
Old Sep 23, 2008 | 06:33 AM
7.3mule's Avatar
7.3mule
AIH delete
anybody know where i can can get a aih delete with the guage port?
Old Sep 23, 2008 | 07:51 AM
mueckster's Avatar
mueckster
I got my plug from dieselsite and drilled & tapped it myself for the fitting. Here is one that is already pre-fabbed and comes with the code eliminator pigtail: Ford 7.3L Air Intake Heater Plug with Boost Fitting & 0541 Eliminator Powerstrok
Old Sep 23, 2008 | 09:28 AM
UP_There's Avatar
UP_There
ITP Diesel, L.L.C.
Old Sep 23, 2008 | 09:54 AM
whitetr's Avatar
whitetr
Originally Posted by UP_There
That is exactly what I did. Drill it out and tap it, install ta fitting and for under $20, you have a AIH delete with boost fitting.
Old Sep 23, 2008 | 09:59 AM
mueckster's Avatar
mueckster
The pre-fabbed ones sound a little pricey, if you can do it yourself. You can fab the code eliminator, too.
Old Sep 23, 2008 | 10:12 AM
whitetr's Avatar
whitetr
Knock on wood, mine has never thrown a code. I just removed the heater and the power cable from the solenoid. Every winter the truck sees temps in the minus teens to twenties. So for me, I don't see that the code eliminator is necessary.
Old Sep 23, 2008 | 10:17 AM
UP_There's Avatar
UP_There
Unless you have scanned them, you'd never know if the code was there, you won't get a CEL with this one, it only throws a soft code. Mine is there when I scan it......it's harmless though, the system is just recognizing when you remove that heater.
Old Sep 23, 2008 | 10:21 AM
mueckster's Avatar
mueckster
I don't have the AutoEnginuity, but I believe that if the PCM cannot "read" certain circuits, some of the tests will abort. The code is a soft code that doesn't set the SES light. I don't get the codes anymore with my code eliminators for the EBVP, AIH, and WG Solenoid deletes.
Old Sep 23, 2008 | 11:20 AM
whitetr's Avatar
whitetr
Aha, you learn something new everyday. I guess I will have to invest in AE like I have been wanting to for sometime now.
Thanks gentlemen.
bobiker
Aug 21, 2013 03:06 PM
bly8397
Dec 27, 2012 09:53 AM
mad modder
18
Oct 13, 2008 09:49 PM
Adam0331
Aug 25, 2008 02:38 PM
JustinSWeber
Jan 7, 2008 12:37 AM
