It removes the Air Intake Heater from the cold side of the air intake spider. This removes a substantial blockage of air flow through the air intake. You can get one here: AIH Delete Plug It explains a little more about it, too.
Will it throw a code or trip the SES? Aren't there wires that go into it?
You can install a wire, with a 470 ohm 1/2 watt resistor soldered inline, to a good ground from the AIH relay post where the red wire is removed. This will stop the code from setting. It is a soft code and does not set the SES light, but will show up when read. IIRC, it is a P0541 code for the AIH.
Don't know, I do know that it is one less electrical problem I have to worry about burning up, plus, now I have an emergency backup relay should my GPR ever go out and I needed a good place to put my boost gauge line. All of which was solved by the AIH delete. Anytime you can remove airflow restrictions, it has to be good. That dang thing is pretty big.
