Code 0775
Old Sep 23, 2008 | 02:05 AM
ParcelPuke's Avatar
ParcelPuke
Code 0775
2002 Explorer V6
"Pressure Control Solenoid B Malfunction"
Every once in a while the "O/D off" lamp blinks very fast. Today the "check engine soon" lamp came on too, and I pulled that code.
I don't know what that is, or even if one is related to the other.
Whaddaya think, guys??
TIA
Paul
Old Sep 23, 2008 | 07:51 AM
projectSHO89's Avatar
projectSHO89
A P0755 fault code indicates that the PCM has detected an electrical circuit fault with internal transmission Shift Solenoid "B".
If the circuit is shorted, you'll loose 1st gear. If the circuit is open, you'll loose 3rd gear. In either event, the O/D light will flash and your CEL will come on.
The list of possibilities include: PCM, vehicle wiring harness, transmission internal harness, or the solenoid itself.
Steve
Old Sep 23, 2008 | 08:39 AM
ParcelPuke's Avatar
ParcelPuke
Thanks for the quick answer, Project! It is code P0775 tho, not P0755. Can you tell me about that?
Thanks
Paul
Old Sep 24, 2008 | 09:21 AM
ParcelPuke's Avatar
ParcelPuke
Anyone else have a good description for P0775?
Old Sep 25, 2008 | 07:04 AM
projectSHO89
Sorry, must have misread the code...
P0775 indicates The PCM doesn't like the results when it commands Pressure Control Solenoid "C" to a specified pressure. Should also cause a loss of 2nd and 5th gears and, as noticed a MIL.
Might be a faulty solenoid body or a wiring/PCM concern. The workshop manual does have a pinpoint diagnostic procedure, however the procedure requires a test device unlikely to be found outside a dealership.
Steve
Old Sep 25, 2008 | 10:04 AM
ParcelPuke's Avatar
ParcelPuke
Excellent, thanks!
Paul
Old May 23, 2009 | 02:00 PM
dsljay's Avatar
dsljay
P.P. I have the same problem. What was your fix and was it expencive??
Jay
Old May 24, 2009 | 08:30 AM
ParcelPuke's Avatar
ParcelPuke
I took it to a Ford dealer who said I would need a new or used tranny. With close to 140,000 miles on it, I did not want to put that much money into it. (Think they said $3300 for the new tranny).
Never even brought it home, traded it in on a 2008.
Good luck!
Old May 25, 2009 | 09:00 PM
dsljay's Avatar
dsljay
Thanks, PP. I was hoping for a less expensive answer.LOL
Jay
Old May 26, 2009 | 07:40 AM
ParcelPuke's Avatar
ParcelPuke
Also look at this thread.
Good luck!
Old May 26, 2009 | 08:25 PM
rrgone's Avatar
rrgone
Look at this thread:
https://www.ford-trucks.com/forums/7...ion-fixed.html
Then look here and scroll down to pages 49 and 50:
http://www.ratiotek.com/5r55w-complete.pdf
Then go here for info on the kit to repair the servo pin bores:
Servo Pin Bore Repair by Northland Transmission
I would definately screen any repair shop very thoroughly to make sure they are familiar with the servo bore issue in the 5R55 trannys before letting them rebuild it. Check with Northland Transmissions to see if they can recommend a local shop that is familiar with their repair kit. Once the 5R55 is rebuilt with the kit it is a good strong tranny. It's a shame that it has this design flaw.
jermort
6.7L Power Stroke Diesel
May 2, 2014 11:11 AM
dannyg1992
Apr 14, 2014 05:43 AM
Pablo69
Nov 27, 2004 11:15 AM
mcoop73
1997 - 2003 F150
Mar 18, 2003 11:38 PM
PAUL_2
Jun 8, 2000 07:42 AM
