Trac-lok ID
Old Sep 22, 2008 | 01:11 AM
Pedestrian's Avatar
Pedestrian
Trac-lok ID
I bought a bronco with a new trac lok in a box. Need to know if it's for the dana 30 front or the 9" rear. Any easy way to tell? It's got 10 bolt holes for the ring gear.
Old Sep 22, 2008 | 11:41 AM
andym's Avatar
andym
What's the part number on the box?
Old Sep 22, 2008 | 12:31 PM
75F350's Avatar
75F350
Both the 9" and the Dana 30 have 10 ring gear bolts. Go figure huh. Thats the kind of luck I have.
Now the spline count is different, and the 9 inch regardless of which will have more splines.
The D30 also has a small 7.2" ring gear, and the 9 inch ford has,,,,(dramatic pause) a 9 inch ring gear.
Now the Dana only uses 3/8" bolts to reatin the ring gear, and the 9 incher uses 7/16" fasteners, so the bolt holes will be different sizes from carrier to carrier.
This is not difficult to figure out, and hopefully you have the information you need to get this figured out.
Good luck
Old Sep 22, 2008 | 06:11 PM
Pedestrian's Avatar
Pedestrian
Thanks, I think that will give me enough to go on. If not I shouldn't be playing with big boy toys.
Old Sep 23, 2008 | 12:42 AM
Pedestrian's Avatar
Pedestrian
Well it ends up being for the front dana 30. Hopefully the PO already installed one in the rear. I'll jack it up tomorrow to find out. Thanks for the help.
Old Sep 23, 2008 | 12:51 AM
75F350's Avatar
75F350
Sure, no problem. Did the clues add up?
What was the determining factors that helped you determine that it was for the D30?
Old Sep 23, 2008 | 12:57 AM
Pedestrian's Avatar
Pedestrian
Less than 9" diameter. actually like 7 something, close enough for me.
Old Sep 23, 2008 | 01:13 AM
75F350's Avatar
75F350
You know, I was just going to post that, and that alone, but I figured I would show of a little, lol.
Glad you got it figured out.
moejr
Apr 24, 2016 09:50 AM
Turbo Dog
36
Mar 5, 2015 04:03 PM
mando jake
Offroad & 4x4
May 26, 2010 04:19 PM
fordxxx
16
May 23, 2006 03:43 PM
fordxxx
May 19, 2006 02:37 PM
