I need 35 spline side gears for a trac lok?
Dang, I just got rid of a set. Ive had several Trac locs fail and you wont find one in any more of my rigs.
Regardless, if you have one, and you want to throw some money at it, Yukon makes the gear set, and they are available anywhere Yukon is sold. (Randys R&P).
Unfortunately, they are spendy, and almost not worth the effort of building a trac loc.
I would think that you could sell your current LS unit, and find a more desirable Power loc and still be money ahead since you have the 35 spline side gears already.
Finding the power loc is not all that hard, and the strength benefits are so much greater.
I do believe that for reliability you will find this benefit by finding a power loc.
Either way, you can find the gears from Yukon.
Not to hijack..... But does that Powr-Lok cause any steering issues in 2wd with the hubs locked?? I have a Trac-Lok that I was gonna put in the front of my F-350. I would rather have a Powr-Lok, but I already have the Trac-Lok. And, I intend on running front drive flanges and I was a little worried about steering in 2wd. I know the Trac-Lok isn't tight enough to cause any trouble..... but what about the Powr-Lok?? I put a Powr-Lok in the front of a guy's truck a few months ago. But, his hubs were busted and I didn't get a chance to try it out.....
I dont have any problems with running the truck in 2wd. I often lock the hubs in before I even get on the freeway and drive to the trail.
I can feel some resistance, but nothing like one light expect, and i run some fairly tight Power locs.
This does require a little finesse when trying to unlock the front hubs though. F350Bronco has taught me a few different ways, but each truck is slightly different.
usually turning the steering wheel back and forth a little bit usually turns the thing enough to allow the hubs to be unlocked, but as far as driving issues, there are none that would not warrant the use of the power loc. (imo)
Thanks. That's kinda what I was expecting. But I got a little scared after I installed the Powr-Lok I was telling you about. I had just installed it with 4.88 gears and backed it out of the shop. I had the hubs locked and attempted to steer. The steering wheel wouldn't budge and the power steering pump started to scream. Shortly there after, the hub let go, then steering resumed. I was 99% sure this was because the unit was new and the clutch plates hadn't gotten lubed up yet. But, it was still enough to make me worry a little........
I'm glad to hear you're able to run it down the highway with no problems. So, I guess I'm not gonna waste my time with the Trac-Lok. I had to rebuild a Ford 9.75 with one last month. After that experience, I swore I would never have a one-piece case limited slip in anything else I own......
Anyone wanna buy a Dana 60 Trac-Lok??
Hey Ed, little power loc question for ya,
My old dana 44 power lock, the case came apart with left hand theaded bolts. My new 35 spline dana 60 power lock comes apart right hand thread. Would you happen to know why? My only thought was because the 44 one came from an international scout rear end which i scored cheap cause the guy hammered on it with an impact, snapped it off and couldn't find a bolt for it lol. It was a good thing I didn't take the Impact to my dana 60 power lock or it would have been the same situation cause I thought it would be threaded the same as the 44 was.
ladelld33
13
04-01-2016 02:45 PM
fordxxx
16
05-23-2006 03:43 PM
razzi
10-26-2005 09:05 AM
ClatonK
01-21-2004 12:21 AM
