its shooting me the code PO136
(Heated Oxygen Sensor ho2s Circuit Bank 1 Sensor 2)
wat could have caused this... how easily is it replaced... & around how much is the replacement sensor?
also.. wats the best place to buy it...
thanks!
This relates to the O2 sensor after the CAT, it is not critical to the operation of the engine. First check the wiring, sometimes chafs or burns, Check the supply fuse for the sensor. The sensor screws out like a sparkplug, and the wire clips into a harness above tranny.
If it requires replacement, RockAuto have decent prices and will provide a discount to forum members.
You can also try resetting it to see if it comes back on. Sometimes they will throw a false code. If the light stays off and it runs ok, I wouldn't worry about it.
hopefully your right marragtop --- i deleted the code 2 days ago and it hasnt came back up ---- thanks aqua... if it does happen to come back on ill give your advice a try.
