Ignition switch help
Old Sep 20, 2008 | 12:50 PM
400-CI's Avatar
400-CI
Question Ignition switch help
How do you take the ignition switch out of a 77 f150 custom?
Old Sep 20, 2008 | 04:35 PM
williamm21's Avatar
williamm21
Always disconnect the battery first. If you insert the key and move to accesory there should be a release pin on the face to remove it.
Turn the key counterclockwise and pull the key and lock assembly out of the switch. The removal of the rest is start taking this apart till it comes out
Old Sep 21, 2008 | 02:17 PM
400-CI's Avatar
400-CI
I took it out, And now I can't get it back in... I tried outting it back in the exact way I took it out, And it gets 25% of the way in and just stops.
Old Sep 21, 2008 | 03:19 PM
400-CI's Avatar
400-CI
Never mind, I got it back in.
Old Sep 24, 2008 | 03:33 PM
400-CI's Avatar
400-CI
Could anyone tell me what this is used for? It is labeled P2, But as you can see, There is a connector on the Ignition Switch, But there is no slot for it to go into.
Old Sep 26, 2008 | 01:58 PM
subford's Avatar
subford
I think you have the wrong Ignition switch as P2 was used on newer Diesels.
How ever you should have a P and this would be the Proof (or PROVE OUT) terminal for the dash lights.
Old Sep 26, 2008 | 04:15 PM
400-CI's Avatar
400-CI
Really!? But my key fits my Ignition and the door locks too, If it was a different switch, My key would not work on the doors, Right?
Old Sep 26, 2008 | 05:52 PM
subford's Avatar
subford
How is all of this working if you can not insert the the plug onto the Ignition Switch?
ctorres
Jan 31, 2017 05:34 PM
IDIoit
16
Jan 26, 2017 05:27 PM
bigcrunch
Large Truck
May 8, 2016 11:52 AM
65rancheroguy
WTB - Parts & other
Oct 12, 2009 05:44 AM
jeff9942
Aug 2, 2009 10:23 AM
