Horrible timming
Old Sep 19, 2008 | 08:52 PM
stroken's Avatar
stroken
Cool Horrible timming
Well now that my very good friend and diesel mechanic is mad at me and all my buddys on here are i got a problem this evening. I had my front end off today messing around painted the bumper and grille and all (will post pics at a later time) buddy used a high heat paint and put a light coat on the ac condenser thingy, i have no idea why, he told me he did after the fact.
Well when I get to my gfs about 15 minutes away steam is comming out of the hood and a light white smoke i noticed while i was backing up. open the hood and the steam is comming from passangerside back were the turbo is but more to the side. i look under the truck and there is a few oil spots on tire valve cover axle ect. not major, truck ran fine. oil filler neck seemed a lil lose but i really dont think it was that.
I know everyone is mad at me but could you please possibly help me out? I have no idea what to do, kris is mad at me so I cant even get his opinion...if you need anymore details let me know and I will answer the best i can, thanks so much guys and yes.....sorry!
Old Sep 19, 2008 | 08:57 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
I'm not mad at you, but dont have any answers either. Wish I did.
Old Sep 19, 2008 | 09:12 PM
xgatorx1976's Avatar
xgatorx1976
I dont think the paint is at fault here. just a small amount of oil it sounds like to me.
I cant be mad at someone I have never meet.
Dont worry people cant stay mad forever, they will get over it hopefully.
Old Sep 19, 2008 | 09:21 PM
F350-6's Avatar
F350-6
Kenny, I'd make sure the people who your apology is directed see it, including sending them a PM to apologize. You've seen your motor out of the truck, so you should have a basic understanding of all the parts.
Did you do anything else besides some painting? What does the smoke smell like? If you get paint or any other liquid on parts of the engine it will smoke as it burns off. If you have an oil leak, it should be easy enough to find on a new engine. Get a flashlight and start by checking the valley. If necessary, grab an inspection mirror and have a look around for the source of the oil.
Old Sep 19, 2008 | 09:53 PM
griesera's Avatar
griesera
Life's too short to be mad...hopefully they will grow outta it...
Old Sep 19, 2008 | 11:36 PM
zack7.3's Avatar
zack7.3
I ain't mad at ya either, but I don't have an answer for ya.
Old Sep 19, 2008 | 11:41 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Im over it, sorry for being a dick. it just upset me and at the time it seemed like the only thing on my mind is what came out.
Best to crawl up on top with a flashlight when it's running and see if you see oil running
Old Sep 20, 2008 | 05:15 AM
ron's power stroke's Avatar
ron's power stroke
I must have missed some thing here but I'm not mad at ya..you saved my butt and I thank you deeply for that... do what's said above..but is it possible the friend got paint on some hot motor parts and its just burning off ??? i hope he went very light with the high heat paint... it could insulate the condenser and not allow it to cool like it should resulting in a not quite so cold air in the cab...
Old Sep 20, 2008 | 07:11 AM
Kwikkordead's Avatar
Kwikkordead
I've seen this many times: A small pinhole in a hose sprays coolant on something hot and the steam starts to billow.
It can be a foot away from what appears to be the problem, but in reality, the pinhole is spraying the coolant from somewhere else.
Old Sep 20, 2008 | 08:09 AM
stroken's Avatar
stroken
thanks guys, i just woke up and gonna head out and look at her
Old Sep 20, 2008 | 08:27 AM
stroken's Avatar
stroken
Can someone help me out on the routing of the coolant lines? The coolant resivour is empty and it may very well be coolant on the motor and not oil. I would like to check for holes and see if the hoses are touching anything but i am not sure where alll the coolant lines run...
does coolant kinda have the same look as oil..like always wet?
Old Sep 20, 2008 | 08:30 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Could it be a split heater hose?
Old Sep 20, 2008 | 08:41 AM
stroken's Avatar
stroken
nope! hole in the block!,,,its a clean hole and it runs so i am hoping a plug goes in there? its on the passanger side right above the starter.
Old Sep 20, 2008 | 08:48 AM
King0581's Avatar
King0581
I'm pretty sure there is a plug in that area thats there to drain the antifreeze out the block. Should be a threaded hole.
Old Sep 20, 2008 | 08:53 AM
stroken's Avatar
stroken
yeah i just felt, doesnt feel like it has threads. Maybe a press in?
Its about the size of a half dollar or maybe a little bigger
