SS HPX questions
Old Sep 18, 2008 | 09:49 PM
glb.thehammer's Avatar
glb.thehammer
Thank Ron & Brent,
Good info and pic's too!
Do'in mine this Sat.
Old Sep 18, 2008 | 10:07 PM
bigsteve1969's Avatar
bigsteve1969
hammer i wish i had went ahead and ordered mine but times are hard ha ha
Old Sep 18, 2008 | 11:13 PM
Izzy351's Avatar
Izzy351
Don't over-tighten, but don't leave it too loose either. I was worried about over-tightening mine -- apparently, 3000psi of oil will take its toll on an O-ring if any at all gets by it. It was almost gone by the time realized it was leaking and replaced it. I ended up putting quite a bit of tourque on mine. Don't remember how much, but it was TIGHT.
Old Sep 18, 2008 | 11:17 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Good point. I tightened mine down pretty tight as well. Oh, make sure you check it every few months, seems like mine likes to vibrate a bit and I can usually give er' a crank now and then to snug her up.
Old Sep 24, 2008 | 08:06 PM
glb.thehammer
HP-X Done
Originally Posted by glb.thehammer
Thank Ron & Brent,
Rained this passed weekend so, wife got some more flooring laid. Mon. & Tues. were already on the calendar.
Got er gone tonignt!
Time for
Hammer Down.
Old Sep 24, 2008 | 08:24 PM
Powerstrokedlariat
Everything go okay?
Old Sep 26, 2008 | 08:14 AM
glb.thehammer
So far so good...Did end up taking the air intake off to get the driver side on.No leaks. Waiting for it to take effect.
Thanks.
Old Sep 26, 2008 | 09:35 AM
IABill's Avatar
IABill
Exclamation
Use the removable lock tight that is recommended it will insure no leaks. I did not the first time around.
Second time around dry as a bone
Old Sep 26, 2008 | 10:05 AM
bigsteve1969
is that the green lock tight or the red? ha ha one of um INSURES lock ha
deerslayer165
May 20, 2010 10:37 AM
87 F-150 I6
20
Oct 29, 2009 05:29 PM
03_PSD
26
Jun 19, 2008 08:54 AM
BigD7575
Mar 3, 2008 10:01 PM
stockernavstar
Feb 11, 2006 08:55 PM
