Offroad & 4x4
Tire shake
Old Sep 17, 2008 | 09:58 PM
73 ford guy's Avatar
73 ford guy
Tire shake
hey what do you guys do to tires like 44's to balance? I've heard about sand and bb's...
Old Sep 18, 2008 | 08:53 AM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
Its called dynamic balancing... I know there are a few write up's on pirate... I dont really understand HOW it works but i just know it does.
Bb's
Sand
Ive heard of some kind of powder being used...
Airsoft pellets...
The only thing that jumps to mind, is bb's and rusting together, if the truck is left to sit for to long, i guess the bb's can rust together in a big glob, which could be very bad if you decided to hop in your truck and take off.
Old Sep 18, 2008 | 09:21 AM
mark a.'s Avatar
mark a.
I've had bb's in mine for years with no issues. They do balance the tire but they can't do anything about a out of round tire, which they all are to some degree. All you can do is put some in & see if it helps. I probably have around a half a cup in each of my 42's.
Old Sep 18, 2008 | 10:11 AM
Truckin4life
Yea ive noticed my tires will flat spot after sitting... But once warmed up there fine... I got lucky... There not balanced and no media balancing... And no shaking
Old Sep 18, 2008 | 10:18 PM
Prozon's Avatar
Prozon
I heard there is a chart somewhere on the net that tells you exactly how many BB's you should use for different size tires.
My dad told me that anti-freeze works and he uses them in some semi-tires.
I have yet to test it myself though, I will soon though.
Old Sep 19, 2008 | 10:23 AM
73 ford guy
Can I just remove the core in the valve stem and put bb's in or do I have to break the bead on wheel?
Old Sep 19, 2008 | 10:32 AM
Truckin4life
I think throught the valve stem would take along time if possible....
I would break the bead... Easiest and fastest in my opinion...
Old Sep 19, 2008 | 07:04 PM
73 ford guy
So I took the tire in to the shop today and put just over half a cup of bb's in tire. Put it on the truck and ran it in the air again and it still has up and down wobble. I wonder if I just need to run my tires on the street for a bit just to get them round again since its been sitting for just over a year. Tires are a 42 swamper TSL and they never vibrated when the truck was last on the road.
Old Sep 19, 2008 | 07:28 PM
Truckin4life
UP and down wobble or a side to side wobble?
Might want to check worn parts steering linkadges, ball joints...
If it was fine when you parked it... The tires could have flat spotted... drive them a few mile say 5 or so, and see if it gets any better... They could have flatened out some... Some road driving could fix it....
Old Sep 20, 2008 | 11:34 PM
iggybob44's Avatar
iggybob44
I filled my 59" Extreme mega-mudmaster mother-mucker radials with popping corn,its the newest trick from the fertile minds of the Moab mall-crawler folks. it works like this,dump approx 4 oz of quality popping corn per each 2" of tire diameter over 38" of diameter(i figured 2-1/2 lbs for my application) i like Orville Redenbacher,and inflate to 30 psi,then drive 50-100 miles at freeway speeds which heats up corn to popping temp and distributes it evenly as it pops! not only do you get perfect balance,the popcorn holds the tire to the bead better than bead locks,which allows airing down for off-road usage,and also in the event of air loss,popcorn works like a run flat tire.... You guys here like to think of yourselves as off roaders, i'd a thought you would have heard all about this by now! im starting to question whether you guys here are real off-roaders,or just mall-crawlin wanna-be posers.................
Old Sep 21, 2008 | 01:23 AM
Prozon's Avatar
Prozon
And, if you pop a hole in the tire you can eat the popcorn while your buddy changes the tire for you.
Pure Genius.
Old Sep 21, 2008 | 01:24 AM
Prozon's Avatar
Prozon
Hahah could you imagine that? Two guys driving down the road with a big mud tire in the front pickin popcorn out of it. :P
RAPR
6.7L Power Stroke Diesel
Sep 12, 2012 02:51 PM
HMS
Dec 11, 2009 10:47 AM
78ford351m
47
Feb 17, 2009 02:11 PM
mattpowerstroker
15
Feb 3, 2008 09:24 PM
mustangmike
May 5, 2006 09:09 PM
