ABS light on dash
Old Sep 17, 2008 | 08:38 PM
moosed's Avatar
moosed
ABS light on dash
Hello all,
Have a 2003 V10 Limited that has the ABS light on the dash on. Just happened today, any ideas on what to check and is this truck safe to drive as is until I can either fix it myself or bring it in to the dealer.
Thanks
Tony
Old Sep 17, 2008 | 08:47 PM
VaSheriff's Avatar
VaSheriff
Just a shot in the dark..... In addition to several other symptoms and malfunctions, my ABS light came on when the wiring inside the steering column had become exposed.
Read this subject..... all 3 pages
https://www.ford-trucks.com/forums/7...uestion-3.html
Old Sep 17, 2008 | 08:52 PM
VaSheriff's Avatar
VaSheriff
This thread covers the exposed wiring problems too. Seems like it's happening to more and more Excursions. And like I said, the ABS light coming on was one of my symptoms as my wiring became exposed.
https://www.ford-trucks.com/forums/7...y-550-tow.html
Old Sep 18, 2008 | 01:07 AM
Monsta's Avatar
Monsta
Sit. Stay.
You could also check the wiring and the sensor on top of the rear diff. You can pull the sensor out and clean it if it is gunked up with stuff. Sometimes that works. The sensor is the speed sensor and the ABS uses it.
Front ABS sensors could also be dirty but that requires you to pull the wheels.
Both are the first things to check (along with VaSheriff's suggestion) since all of them don't cost anything but time.
Old Sep 18, 2008 | 08:05 AM
moosed's Avatar
moosed
Thanks guys for the fast reply. Yep I have followed the steering column wire thread and will check that and the sensor on the rear diff as well. BTW the light went out this morning.
Monsta: where on the front are the sensors after the wheels come off?
Thanks again for the fast replies.
Tony
Old Sep 18, 2008 | 01:38 PM
Monsta's Avatar
Monsta
Sit. Stay.
For the front brakes on a 4x4:
"B" is the sensor. "A" is the electrical line.
(ABOVE) For rear axle sensor. #2 is bolt, #1 is plug from harness.
Clean and inspect the rear axle speed sensor.
1. Clean the axle mounting surface.
2. Inspect and clean the magnetized rear axle speed sensor pole piece.
3. Inspect the rear axle speed sensor O-ring for damage. Install new if necessary.
4. Lightly lubricate the rear axle speed sensor O-ring with rear axle lubricant.
Old Sep 18, 2008 | 01:52 PM
moosed's Avatar
moosed
Those are great !!
Thanks
Tony
Old Oct 17, 2008 | 12:39 AM
fordcountry's Avatar
fordcountry
I just finished this process tonight. Sure enough the VSS was gunked with lots of muck! I cleaned it off and put it all back together... no more ABS light.
This site is the best!
Trigger1911
Jun 10, 2023 05:07 PM
riotstick
2009 - 2014 F150
18
May 13, 2017 01:42 PM
OD_ONE
May 23, 2015 08:18 PM
otter2208
Apr 29, 2003 04:15 PM
Mar 12, 2002 05:05 PM
