Hello to all I was wanting to know if anyone might know what is wrong with my overdrive shutoff switch. When I push the button on the end of my gear selector the off light does not come on and the tranny will still go into overdrive. Anyone with a solution please let me know. Thanks Brandon my truck is an 02' 4x4 auto tranny f-350
Relatively common problem. This is a momentary contact switch, and over time the contacts can get dirty, corroded, bent, worn, etc depending on use. You can remove it and clean it, or just get a new one. They're cheap as Ford has been using the same switch in many models for years. Even Dorman sells one in their "HELP" line.
Ask any knowledgable person at a parts store for a Ford Overdrive Switch and they'll be able to help you.
