Power Steering Arrr
Old Sep 16, 2008 | 10:20 PM
bakerbuilttracks's Avatar
bakerbuilttracks
Power Steering Arrr
Ok well im new to the site and have looked at the forms quite a bit to get advice. yall shure know ur trucks. i have a 2000 f250 sd and i love it except right now i wanna strangel it. when turning left or stopped at a light after some time of driving i get this wicked grinding noise. i can be stopped and start to turn the wheel left and it increases. to the right alls good. put a new p/s pump in and the same result. it sounded like the pump? when i hit a bump while turning i seems it gets worse on the compression of the suspension. anyone any clue. maby the steering gear box?
Old Sep 16, 2008 | 10:37 PM
nhill2090's Avatar
nhill2090
Are we talking like a whining or grinding noise?
Sometimes obvious, but are you sure your PS reservoir is full...and of ATF at that?
Old Sep 16, 2008 | 10:55 PM
bakerbuilttracks
Its a grinding noise not whining and i got full synthetic ATF fluid in her and shes reading full on the stick. it sounds like a wheel bearing went out "grinding" noise. but it dose it when stopped and intensifys if i turn to the left
Old Sep 16, 2008 | 10:59 PM
nhill2090's Avatar
nhill2090
hmm, if thats not it, it probably wouldn't hurt to jack up the front end and make sure you have no play in the front end
Old Sep 17, 2008 | 03:51 PM
bakerbuilttracks
yea i did and everything is super tight just got new ball joints drag link the whole 9 yards its deffently something in the steering system cuse when the trucks stopped and the brakes are applied or u turn the wheel it grinds. more brakes or the more u turn the louder it gets. im truly stumped! maby a loose pully or brake booster or the steering gear box?
Old Sep 17, 2008 | 03:57 PM
Ponyboychris's Avatar
Ponyboychris
2WD or 4X4 truck?
Old Sep 17, 2008 | 04:13 PM
nhill2090's Avatar
nhill2090
hmm, maybe you can search for a way to diagnosis the hydro boost system..
Old Sep 17, 2008 | 08:01 PM
bakerbuilttracks
its 4x4 . . . . whats the hydro boost system
brenthottle
Jul 11, 2014 06:02 PM
Dresser77502
2004 - 2008 F150
Aug 17, 2013 12:52 PM
1sscav
1978 - 1996 Big Bronco
Jul 25, 2011 02:01 PM
sedly
Feb 18, 2009 02:17 PM
Northriver
Jun 20, 2007 08:36 AM
