Caution: Kris Myers
Old Sep 16, 2008 | 09:24 PM
  #76
Tenn01PSD350's Avatar
Tenn01PSD350
This too, shall pass.
Old Sep 16, 2008 | 09:41 PM
  #77
Dockboy's Avatar
Dockboy
Originally Posted by strokin_it7.3
And another thing, i feel like a whiney bitch blowing up my motor for the first time (even though im not really suprised, mad, or whining) compared to Dockboy who has perfected the art of blowing up engines. BTW greg, is your truck back together? Im expecting to see it october
LOL No problem Kris!!
Unfortunately, I won't be finished by Fall Brawl I'll be there, just not with the truck. I'm picking the block up from the machine shop this week. Probably be at least another month or two before the truck is running. I'm shooting to have it done for some shakedown passes at Cecil for the SOTN Fall Nats in Nov.
Old Sep 16, 2008 | 09:55 PM
  #78
Tenn01PSD350
Well don't blow it up this time Greg. I am looking forward to seeing you put the beat down on some folks at smokin. If your truck does not make it this next time, I may be forced to give up on you. You know, that strike three thing and all.
Old Sep 16, 2008 | 10:13 PM
  #79
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
If you dont want to post in the forum, can you PM me what youre doing to the bottom end and rotating assembly this time?
Old Sep 16, 2008 | 10:45 PM
  #80
Kwikkordead's Avatar
Kwikkordead
Well, I want to know this too!!!
Please post it here.
Old Sep 16, 2008 | 10:59 PM
  #81
Dockboy's Avatar
Dockboy
The Cummins CR stock bottom end is plenty strong enough for 900-1000 hp and wasn't the cause of my failure. I had a hung injector which caused a piston to crack and it seized in the bottom of the bore. The rod had nowhere to go but out the side!!
I am doing a few things different though just because i'm building it from scratch. It is an 05 block which has better piston cooling and I'm using QSB 480 Marine pistons which have the later piston cooling galleys but have the earlier combustion bowls. I'm also using 24V forged rods that are peened with A1 rod bolts. Rotating assembly is balanced and the block is o-ringed. Also will be running a billet cam and tappets.
Old Sep 16, 2008 | 11:44 PM
  #82
Powerstrokedlariat's Avatar
Powerstrokedlariat
I'm drooling over this...
Old Sep 16, 2008 | 11:55 PM
  #83
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Originally Posted by Dockboy
The innuendos that the DP Tuner 80hp Economy program are the reason for this, or any other failure is not only laughable, but shows utter lack of knowledge of exactly what happens
Hahahaha. There is no DP blaming, 75% of the time I/me/myself is in the 80tune. Knew what I was getting into and still going to do. I can write the check. Don't mean to make this sound neg. at all, just .02 regarding my comment and this quote.
Kris, still would like to know what signs you were starting to feel, see, hear and whatever else, that your motor was on its way.
Old Sep 17, 2008 | 02:13 AM
  #84
jtharvey's Avatar
jtharvey
Nice! I knew about the pistons which you had told me about, but the other extras should make that one strong SOB. Can't wait to see it. I know you were just starting to tap into the potential of your setup.
Old Sep 17, 2008 | 08:37 AM
  #85
superduty4x4's Avatar
superduty4x4
So here's a question that crossed my mind on my way to work this morning- it seems like most guys that grenade the motor don't do it when they are working the truck hard, it's typically at low speeds (20-35 mph) taking off from a stoplight from what I've read on at least this forum. Why are the failures tending to occur in these circumstances instead of under higher stress conditions?
Old Sep 17, 2008 | 08:42 AM
  #86
F350-6's Avatar
F350-6
Re-read Dockboys post since he's got plenty of experience with this. The fractures are occurring when you would expect them to, they just finally let go a little later.
Old Sep 17, 2008 | 08:46 AM
  #87
Kwikkordead
I am drooling over this too. Thank you for posting.
Old Sep 17, 2008 | 08:47 AM
  #88
superduty4x4
I understand that Chris, its just odd that a fair amount of the blown 7.3's seem to let go when the motor isn't being pushed harder than normal.
Old Sep 17, 2008 | 09:09 AM
  #89
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Ummmm Maybe we should then push these engines relay hard and never not push them so there isn't a time for them to break
Old Sep 17, 2008 | 10:45 AM
  #90
superduty4x4
You try it and let us know how that works out for you
hotroddsl
Jul 20, 2011 11:35 AM
stroken
23
Sep 24, 2009 03:52 PM
stroken
Oct 25, 2008 05:52 PM
stroken
Jul 24, 2007 09:42 AM
