Some changes coming up!!
Old Sep 17, 2008 | 10:44 AM
tjbeggs's Avatar
tjbeggs
Well many times when you add a chip or bigger injectors the stock HPOP can't keep up with the oil demand. So you add another pump to keep up with the demand. There are quite a few options out there now for how to go about this but they all cost $1500-2500. I am cheap. So I am building my own that will pretty much be a copy of Swamps Gen 3 system. I was gonna build a copy of the stock pump inline but then found what I needed to build the swamps setup rather than getting a machine shop to build the adapter.
The Gen 3 setup consists of a International HPOP reservoir that also houses the gear drive for the power steering pump on the international truck. Swamps has a custom gear made to fit a hydraulic pump. I will just modify the gear I have to fit a standard Haldex pump then plumb it into the the stock HPOP. And I should be around $500 for the whole works.
Old Sep 17, 2008 | 10:48 AM
Talyn's Avatar
Talyn
oh! Dual HPOP
I was thinking in a different mindset.
GG.
Greg5OH
Jul 23, 2014 03:34 PM
Greg5OH
Jul 15, 2014 03:57 PM
iditurbo54
52
Sep 25, 2012 04:48 AM
Redneckryder
Michigan Chapter
Jan 4, 2011 06:38 PM
payableondeath6
19
Jul 24, 2007 06:17 AM
