I recently aquired a transfer case and was told it was an NP 203. I am starting to question this because the NP 203 is a full time chain driven case right? Well this case sounds like it is gear driven and has a cast iron case weighting a ton. I pulled some numbers off the tag: Asembly # D8TA-7A195-AA, Model 2 20, Ratio 1.96, Serial 01-21-78. Is this the 205?
[updated:LAST EDITED ON 13-Aug-02 AT 01:37 PM (EST)]If memory serves, I think one side of the 203's case is aluminum. The 205 is ALL cast iron. I just went thru this same thing identifying the 205 in my 79 donor mobile.
Later,
