1978 - 1996 Big Bronco
Transfer Cases
Old Sep 8, 2003 | 03:59 PM
lightninsniper's Avatar
lightninsniper
Question Transfer Cases
I have a 83 bronco that i have just purchased. What is the difference between the million transfer cases for it. Dana 21, NP203, NP205, and NP208 Which one is better or are they all about the same, and will they interchange. I haven't seen which New process I have, but i was considering a gear driven case. Which one is gear driven or the best out of all of them.
thanks for the help
Old Sep 22, 2003 | 01:12 AM
Peter Bowler's Avatar
Peter Bowler
Transfer Cases
See if you can get onto a page I found on the net .
C.J Fords transfer case information sheet.
Old Sep 22, 2003 | 06:47 AM
1991fseries's Avatar
1991fseries
Transfer Cases
the dana 21 was inly in the early broncoe, the NP 203 was a full time 4 wheel drive transfer case which was offered from 78-79, the NP 205 was the standard part time four wheel drive transfer case starting in 78, the NP 208 was the transfer case in newer bronco's I think they switch over to that in the mid to late 80's. I think the 205 is the best transfer case because it is a part time transfer case and has a lower gear ratio then the 208. the dana 21 is fairly weak and won't hold up to much that the full size bronco can give it. the np 203 and 208 are good transfer cases the nice thing about the 203 is that it's full time and has HI, hi lock, lo, and lo lock abilities, the np 208 is decent and works good on the road with it's higher gearing, and off road durability.
Old Sep 22, 2003 | 08:10 AM
lightninsniper
Transfer Cases
Thanks alot. My brother-in-law has a 79 ford 3/4 ton. his transfer case is made of cast iron and is gear driven instead of chain. I am thinking of getting a tougher transfer case. thanks alot for your help.
Old Sep 22, 2003 | 09:15 AM
sideout2's Avatar
sideout2
Transfer Cases
The 205 dose not have a lower low range gear ratio. It is only 1.98:1, it is however the toughest by far. It is gear driven. The 203 has a gear ratio of 2.0:1 and is chain driven. It is still a good case though. In 1980 I think Ford went to the 208 which has a gear ration of 2.62.
Old Sep 22, 2003 | 02:18 PM
Steve_Uzi's Avatar
Steve_Uzi
Transfer Cases
Rumor mill has it that someone is making a gear swap kit for the NP-205's to make it 3:00 to 1
Old Sep 22, 2003 | 02:30 PM
lightninsniper
Transfer Cases
My tansfer case for my bronco is a NP-208 I would like to get a gear driven case. Would a 205 that is gear driven bold up or is there a tougher one.
Old Sep 22, 2003 | 03:04 PM
Steve_Uzi's Avatar
Steve_Uzi
Transfer Cases
A NP-205 will bolt up as long as you get a FORD NP-205. I got mine from a 1978 Bronco, it is not installed yet but someday it will get put in my beater bronco.
Old Sep 22, 2003 | 03:17 PM
lightninsniper
Transfer Cases
Do you like your bronco w/ a 460. does it have alot of power. Mine has a 5.0 H.O. out of a mustang.
Old Sep 22, 2003 | 03:59 PM
Steve_Uzi's Avatar
Steve_Uzi
Transfer Cases
Power Heck Ya! I can be doing 65 on the highway.. bury the pedal it will kick down and the 4bbls open up and I am doing 90.... and that is with 3.50 gears.. eventually it will have 4'10's
I rarely drive it that fast... mostly because it is a bit insane... I tend to drive 65-70... milage is pretty consistent up to 70... over 70 it starts to guzzle gas...
Old Sep 22, 2003 | 06:36 PM
AYoungblood's Avatar
AYoungblood
Transfer Cases
I just looked at mine, it say "Borge Warner"
And there was a bunch of numbers below the name, but i didnt have a pan at the time.
Which one(s) is that?
Adam
Old Sep 24, 2003 | 09:50 AM
lightninsniper
Transfer Cases
from website
http://www.high-impact.net/transmiss...m#transfercase
Ford) Borg Warner
These cases vary from model to model, however will generally acceptable for use in light and medium duty off road use in the size and weight vehicle they came in.
Old Sep 24, 2003 | 02:23 PM
greystreak92's Avatar
greystreak92
Transfer Cases
Borg-Warner T-case in a Bronco is a model 1356. They were available either with a manual shift or an electronically shifted version. Personally if I could find the necessary components I am going to try and swap my 1356 from electronic to manual...less margin for error.
Old Sep 24, 2003 | 02:55 PM
lightninsniper
Transfer Cases
Old Sep 24, 2003 | 03:25 PM
AYoungblood
Transfer Cases
Well i got the manual, and its nice, solid and no leaks!
Thanks for the info!
How would it rate to the above mentioned tcases?
Adam
