Low Voltage Lighting Question
Old Sep 13, 2008 | 09:49 PM
Bruker's Avatar
Bruker
Question Low Voltage Lighting Question
I have an Intermatic 300watt transformer that I currently am only using 219watts of. I'd like to add a couple of 50watt lights in my system but that will put me 19watts over the rated capacity. Do you think this will cause a problem or will it be OK?
Old Sep 13, 2008 | 10:12 PM
Lead Head's Avatar
Lead Head
For a 300 watt transformer, I wouldn't go over a 275 watt load. I always like to keep a tiny bit of headroom. I've messed with transformers like those before, low wattage one. Usually when you start going over the wattage rating, they will get to hot and a thermal fuse will blow rendering the transformer useless, i've had other transformers fail in more spectacular ways from over loading though. A portion of the winding insulation melts and shorts out, transformer in turn starts getting even hotter, and next thing you know you have hot molten insulation blowing out the transformer and sparks going all over the place.
I personally wouldn't risk it.
Old Sep 14, 2008 | 12:28 AM
fmc400's Avatar
fmc400
MSEE
Don't exceed the wattage rating, and as suggested, it's best to stay under it for added safety margin.
Old Sep 14, 2008 | 10:49 AM
lenny1carl's Avatar
lenny1carl
there will definetely be a problem if it catches fire and the insurace co refuses to pay for exceeding the rating
Old Sep 14, 2008 | 11:09 AM
Bruker's Avatar
Bruker
Those are the answers I thought I'd hear.
Old Sep 14, 2008 | 11:26 AM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
you could safely run 1 light off it. But not two.
Old Sep 14, 2008 | 08:24 PM
rangersvt04's Avatar
rangersvt04
yes 1 but not two.
transformers are pretty cool, ive gotten to play with a few.
Old Sep 14, 2008 | 08:46 PM
Lead Head's Avatar
Lead Head
Especially ones that put out 10,000 volts
Old Sep 14, 2008 | 08:48 PM
MisterCMK's Avatar
MisterCMK
You should try and keep the load to a max of about 80%, so 240 watts on a 300 watt xfmr
daddio360
13
Feb 24, 2008 04:34 PM
omni
17
Jan 12, 2006 10:38 PM
A_G
26
Aug 5, 2005 09:24 PM
bigredtruck
Mar 24, 2005 10:30 PM
jonm61
Oct 4, 2004 02:16 PM
