bent chassis
Old Sep 14, 2008 | 02:01 PM
'51 Ford's Avatar
'51 Ford
Thanks for all this information.
In the Netherlands I don't think it's allowed to bolt a frame together, the rules are very strict. Is it also possible to leave the rivets and weld it also together (after it's chemical cleaned)? Or will that also crack?
Old Sep 14, 2008 | 04:29 PM
dave boley's Avatar
dave boley
It won't crack if it is done right. You need to preheat and use a controlled cool down. The right rod or wire in the case of a MIG is essential. Find out what the composition of the steel alloy is and then go on a welding site and find what rod or wire is recommended.
Do you have to weld it? If the rivets are fine can you leave it as it is? Do they require that you have a certified welder do the work?
Later Man...
Old Sep 15, 2008 | 11:22 AM
'51 Ford's Avatar
'51 Ford
I'm not sure if the rivets are in good shape. first I will make the frame straight and than clean it. Than I'll see if I should replace rivets or weld it together.
thanks
Old Sep 15, 2008 | 11:36 AM
dave boley's Avatar
dave boley
thanks
Create a gallery and put some pictures in it to start with and then keep it updated as you progress through the project. We like pictures...
Later Man...
Rooie gek
Aug 11, 2008 12:14 AM
Rooie gek
New Member Introductions
Aug 9, 2008 05:22 PM
MiMi
Jun 3, 2005 09:10 PM
economustang
Oct 13, 2004 06:26 AM
pim
Aug 20, 2003 02:09 PM
