Sponsored by: Auxito
Code P0503
Old Sep 12, 2008 | 08:43 PM
coryandlyndsey's Avatar
coryandlyndsey
Code P0503
Overdrive light flashes, Speedometer Bounces around , and trans shifts different.
Keep Getting the code and replaced the VSS sensor and tested the wiring to the sensor. Does anyone know what voltage you are supposed to have at the sensor. My haynes manual told me 5 volts but I only have 0.3 volts. Also can the GEM be replaced because the more I look at the problem the more I think that might be my problem. And where is it?
!997 F150 215,000
Old Sep 12, 2008 | 10:05 PM
jk080's Avatar
jk080
Transmission Rebuilder
If this is a 4x4 check for a loose or damaged DRIVE gear on the output shaft of the transfer case.
Old Sep 13, 2008 | 06:56 AM
projectSHO89's Avatar
projectSHO89
You need to tell us which tranny you have and whether or not it is 4 X 4.
The VSS signal does not go through the GEM module. Why would you suspect it?
Steve
Old Sep 13, 2008 | 03:03 PM
coryandlyndsey
yes it is a 4x4 and how would I check that drive gear? Take the trans apart or what. Thanks for the advice. Not sure what trans but its a 4.6L and I'm sure they only put one automatic trans in with that engine.
Old Sep 13, 2008 | 03:04 PM
coryandlyndsey
According to my chilton manual it does have something to do with GEM. The signal from the Vss goes to the GEM and the PCM.
Old Sep 13, 2008 | 04:44 PM
jk080's Avatar
jk080
Remove the speed sensor and look inside the hole where the sensor was, there should be a gear in there. It should only spin with the output shaft.
If you can spin the gear remove the rear drive shaft and the small extension housing on the transfer case, inspect the gear to see why it loose from the shaft.
Dave042
1997 - 2003 F150
Jan 19, 2016 09:22 PM
carrcreekcaller
Jan 16, 2012 05:13 PM
Jimmat
Electrical Systems/Wiring
Jan 22, 2010 07:05 PM
sierrason
1997 - 2003 F150
Nov 22, 2009 02:49 PM
Hanky
Feb 10, 2001 12:49 PM
