Ford Ranger code P0135
I posted this problem back in 2003. I know more about the problem today so maybe I can get some help.
I have a 2000 ford ranger with 4 cylinder engine. The computer is EEC-V.I have the code P0135..O2sensor heater ground.
I measure the voltage on pin 95 of the PCM and get 12 volts at startup. After the engine has ran for 1.5 to 2 minutes the pin goes to ground and reads about .457 volts. I believe the problem may be that the computer is slow to turn the heater on on that sensor, but I don't know why. The truck seems to run good other then the mil light on.
Any help would be appreciated
Thank You
Jim
OBD-II Trouble Code: P0135 Oxygen O2 Sensor Heater Circuit Malfunction (Bank1, Sensor1)
