7.3 flexplate on 6.9 engine
Old Sep 11, 2008 | 08:47 PM
Burninoil's Avatar
Burninoil
Exclamation 7.3 flexplate on 6.9 engine
I am trying to complete my 7.3 to 6.9 swap and need some info.
Can I use my 7.3 flexplate on my 6.9 engine or will it throw the balance off?
I am trying to install a 6.9 on a E40D trany. If I have to use the 6.9 flexplat how thick does the spacer have to be. Oh and it is my first post on here, thought I would come join the cool people
Old Sep 11, 2008 | 10:18 PM
Burninoil's Avatar
Burninoil
please help! Someone has to know
Old Sep 11, 2008 | 10:57 PM
PLC7.3's Avatar
PLC7.3
This is the info I send out, BUT others have done the changes with no adverse results supposedly........so maybe they will chime in!!
Flywheel -
IMPORTANT. DO NOT USE 6.9 flywheel or vibration damper on 7.3 or vice versa. If components are intermixed, engine vibration and premature component wear may be encountered. For identification, compare these part numbers.
Vibration damper 6.9 1805414C1
Vibration damper 7.3 1809117C1
Flywheel Auto 6.9 1803219C1
Flywheel Auto 7.3 1809212C1
Flywheel manual 6.9 E7TA-6477-AB
Flywheel manual 7.3 E8TA-6477-AA
Old Sep 12, 2008 | 05:29 AM
Dodge/Cummins's Avatar
Dodge/Cummins
Welcome to the sight!
Like your user name!
Old Sep 12, 2008 | 01:40 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Although it is not an auto tranny, I used my 6.9 flywheel on three different 7.3 engines.
There were no strange vibrations on any of them.
Going the other way should not make any difference.
I have seen far more internal engine parts swapped between the 6.9 and 7.3 than anyone will tell you will work.
Old Sep 12, 2008 | 07:02 PM
Burninoil's Avatar
Burninoil
thank you sir, I am going to finish swaping parts now, need to get this thing going by monday!
Old Sep 12, 2008 | 11:17 PM
ford trans tech's Avatar
ford trans tech
there is no difference in balancing
the early flywheel was a cast shell with a seperate flex plate installed inside it
this was used on 6.9 and 7.3 and the late 7.3 idi had a regular stamped steel flywheel
but the late stamped flywheel requires a crankshaft spacer , the early flywheel did not
Old Sep 13, 2008 | 09:19 AM
Burninoil's Avatar
Burninoil
thank you sir, i was looking at the flexplates on both and they appear to have same balance the 6.9 is just a lot heavier, I put the 7.3 flexplate on mine.
Old Jul 13, 2011 | 11:53 AM
iney's Avatar
iney
6.9 DIESEL FLEX PLATE????
I am looking for a 6.9 Flex plate f-350 automatic for a 1986 diesel truck and am ready to pull my hair out! Does anybody know where I can buy one??
Can I use a 7.3 flex plate???
PLEASE HELP!!
ineycarr@hotmail.com
Old Jan 29, 2013 | 09:17 PM
turp's Avatar
turp
I am changing a 1991 7.3 to manual trans. how and the heck do you get the spacer off the crankshaft??? I am planning on installing a manual trans. flywheel from 1983 6.9 engine. That will work right?
Old Jan 30, 2013 | 04:37 PM
mattb77's Avatar
mattb77
me too
PLEASE HELP!!
listen i cant help you find one but i am also looking so if you find one let me know and i will do the same
FordTruckfan89
13
Apr 24, 2023 08:53 PM
Racerjay
Jul 13, 2017 09:45 PM
genscripter
85
May 9, 2017 10:02 AM
topgunn
22
Oct 29, 2009 05:55 PM
MECHANICTIME
Apr 22, 2007 11:25 PM
