89 7.3 idi flexplate
Old Mar 1, 2017 | 07:11 AM
FordTruckfan89's Avatar
FordTruckfan89
Sounds like my flexplate is going out, has anyone used the atp z342 flexplate since the ford one is no longer available?
Old Mar 1, 2017 | 09:05 AM
kb1jid's Avatar
kb1jid
If you have the E4OD trans I think you need the Z344 flexplate. The z342 is for the C6 trans They may interchange?
Old Mar 1, 2017 | 01:06 PM
FordTruckfan89
Z344 is for the trucks with the crank spacer, a z342 is the old cast iron flexplate without the torque converter plate.
Old Apr 20, 2018 | 08:07 AM
N2snow2's Avatar
N2snow2
Has anyone had any luck using a different fly wheel or flex plate I’m on a budget and can’t seem to find a factory used one anywhere i have found 2 in United States and no one is interested in shipping it I live in Iowa if we can’t find a solution soon we will have to give up on this truck any info would be greatly appreciated thanks in advance...
Old Apr 20, 2018 | 08:41 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
I've replaced both of mine,in my trucks with the ATP Automotive Z-344 and they've been good.It's those with the factory turbo blocks who have it hard,as they don't make an aftermarket one.I suppose if a feller was smart he could buy the NA flexplate and take both the new and his turbo balanced in somewhere,to be reballanced to the turbo specs.Those of us with the more common N/A blocks though,have the Z-344 bolt in option.
Amazon Amazon
Old Apr 20, 2018 | 12:16 PM
N2snow2's Avatar
N2snow2
Mine has a flywheel with teeth and this plate that the torque converter bolt to the plate all ford dealer can tell us is we don’t have or make it and when I ask people at salvage yards they think it’s a flywheel I even had a guy tell me do the research but I have and I’m not able to drive 12 hours away to get part is there away to cross reference the part to see if there is a replacement no one else can seem to find it
Old Apr 20, 2018 | 12:43 PM
genscripter's Avatar
genscripter
I wrote a little about the differences between my '94 E4OD Flexplate and my '88 C6 Flexplate on my blog a while back when I did the rear seals.
There were SUBSTANTIALLY different. The C6 was probably 5x the weight of the E4OD flexplate. Also, the E4OD had this odd spacer plate that was something like 1.25" thick that pushed the gear out a bunch. I suppose that was to move the teeth closer to where the starter could reach them (the C6 flexplate was just really thick all around, so it didn't have a thick spacer. It has just a thin 1/16" spacer, shown in FORDF250HDXLT's photo above.).
. I don't know if that thick spacer impacted the distance to the TC for the E4OD, but I suspect it does. I'd wager that if you tried to swap the flexplates, you'd have to swap out the TC's as well, and ultimately, that wouldn't work with the other transmission anyway. Also, I'd wager that different TC's have different 4-bolt mounting locations, just to make it impossible to install the opposing Flexplates or TC's, but I never measured that.
Here's a picture of the E4OD spacer:
The flexplate mounting bolts went through the holes on the spacer into the crankshaft.
Here's the crank and rear seal with the E4OD spacer removed:
Old Apr 20, 2018 | 04:19 PM
kb1jid's Avatar
kb1jid
some one is selling the plate that you need near boston on craigs list but he has it listed as a zf5 flywheel I do not know how to post a link on here
Old Apr 20, 2018 | 05:53 PM
trackspeeder's Avatar
trackspeeder
The junk yard is right. It is a flywheel. The flexplate attaches to it. This part was used on C6 and E4OD trannys until 93. Then Ford switched to the stamped flexplate.
You can use the aftermarket stamped plate in place of the early flex/flywheel. There is a catch, you need to find the spacer. This part is obsolete. so its back to the junkyards, or try a transmission shop.
Old Apr 23, 2018 | 06:34 AM
FordTruckfan89
The Ford stamped flexplate is $200 from the dealer, I bought mine last year
Old Apr 24, 2023 | 10:23 AM
GerryL's Avatar
GerryL
thread bump idi flexplate
I have a 1994 F250 7.3 idi (originally normally aspirated) with E40D. Last fall I heard a noise that I suspected was a cracked flexplate. Since It's a summer vehicle only, I wasn't in a rush to fix it. Now I am, but I am running into trouble with parts not being available. I had been trying to get one from Justin at IDI Performance, but I've given up after hearing him say watch the website, they'll be up within 2 weeks (since last October). Anyway, I did buy what is supposed to be a NOS F3TZ6375B from an eBay vendor, but it is not a direct fit as it is much shallower than my assembly (maybe with a spacer?).
I'll attach some information; the pdf is from Ford. My assembly is the middle one pictured with a cast iron flywheel with the ring gear pressed on it, along with a stamped steel flexplate to bolt the torque converter to. Also in photos will be my assembly along with the NOS flexplate I got. I'm wondering if this NOS flexplate will work if I get a spacer machined to space it away from the crankshaft flange. I'm not sure what the balance is on this.
I've also just talked to ATP performance tech support, and they say that neither the Z-342 or Z-344 flexplates mentioned earlier in this thread will work. ???
Thoughts? Solutions? I've scoured used parts/recyclers and new machined flexplate companies, but these parts appear to be made of unobtanium.
Old Apr 24, 2023 | 07:33 PM
bulletpruf's Avatar
bulletpruf
Pretty sure you need the thin flexplate with the spacer. If you need a spacer, I have one that I can sell cheap. I have a flexplate, too, but mine may be for a turbo IDI with a different balance; have to check.
Old Apr 24, 2023 | 08:39 PM
GerryL's Avatar
GerryL
Hi Scott, thanks for the reply. I will keep your spacer in mind. I was hoping to find the correct flexplate so I can keep using my heavy cast iron flywheel; I like the inertia factor of it, as I am looking for torque, not fast revving. And amazingly, after I posted today, I might have found a source with the help of a Ford parts manager that was willing to dig for some obscure part numbers. If it pans out I'll post the info here for others.
P.S. I checked out your first video; nice! Now I am going to have to go back and see more.
Old Apr 24, 2023 | 08:53 PM
bulletpruf's Avatar
bulletpruf
I hear you on the inertia. Good luck with it and thanks for checking out my YT channel.
Scott
Chippenwhales
15
Nov 11, 2025 10:18 PM
Brant Bowrifle
Sep 10, 2023 10:10 PM
Twistedwrench
WTB - Parts & other
Nov 6, 2012 06:36 AM
lite-rescue1233
Feb 3, 2011 04:15 PM
banjopicker66
Apr 10, 2010 10:27 PM
