I've got a 390 with a holley 650 , stock everything else as far as I can tell.
How can i be certain it's too much carb for the beast.
I am planning a HE conversion, will this possably cure the bogging blues?
I have the same problem in my Bronco with a 351M...I bought the Holley 4150 650cfm electric choke vac. secondaries. But I over carbed for a reason. And I'm gonna fix it the only way I know how, cam, headers, 400 crank. Nothing like a few more ponies to fix the problem. Since you said yours is relatively stock, instead of getting a new carb to correct the bogging, I would throw a little extra money at it and go with a few performance goodies.
Yeah, that's what i was thinking. This truck is my first, and the PO did the swap. I am starting to do bodywork and while I have it apart, want to take the opp to do some engine tweaks......hee hee hee
It's gunno take alot of stall convertor(and gearing) to get rid of the bog. Double pumpers are just not good street carbs for trucks. Wayy to heavy and slow. A good tuned vacuum carb will out run it every day.
Either that, or learn where the secondaries open and stop stomping right past it
You don't need full throttle (even with just the primaries) to get full power off-idle. If you lean into it, with a quick partial snap right at the start, you could learn to deal with it
Try dual side-draft Webers on a 4-cylinder. You learn real fast where the bog line is...
Yeah, Moms 80' was exactly the same LOL.. ran like a scalded dog once it was wound up, but don't try to roll out into it. Big4banger/4speed loved that little turd hummer
Wiked, a 650 is not even close to too big for a 390. But if you do in fact have a doublepumper, those aren't considered truck friendly. If you have a bog from the DP opening the throttles too quickly, that would not be a surprize. But a HEI conversion, if that is what you meant, will not help. HEI is just junk stuff for a chevy. The problem they have is that all of the brains for the thing is cooking inside of the dizzy. A better way to go would be a nice duraspark with extra bushings .....the folks who sell HEI conversions probably have them.....and then your trigger box can be out in the breeze someplace. I used to like a Standard Motors LX101 box, but I don't think those are USofA made anymore. But the old ones I have still work. DinosaurFan
When I installed the 406 3X2 on my stock 390 when I first got the setup I had to install a heavy return spring on the front carb because the engine would stumble and then go if you didn't give it a chance to put some revs on before you showed it the end carbs. The 428CJ did not have that problem. Side-draft Webers should be against the law, they will give you gray hair in your 20s.
I ran a 750 Holley double pumper on a 352 and never had any negative issues. I don't have any idea what the story was on the insides of the engine (bigger crank, compression) but that engine ran great.
Even the 360 horsepower 352 didn't run that big of a carb. I would suspect you just didn't know what to look for, to know how badly over carburated it was.
Well I run a Vac 750 on my stock 352.......BUT.............I basically use it as a 375 cfm 2bbl carb. It don't pull enough vacuum to open the secondaries(or turn enough rpm). It purrs like a kitten, idles smoother then any Autolite carb. I had it, I used it, works fine.
Had I needed to BUY a carb, it would have been a 600 vac Holley. I basically used what I had laying around.
Worlds of difference between a 750 vacuum secondary carb and a double pumper.
It is very possible that a quality ignition system can cure your bogging blues.
However, if you are experiencing a carburetor problem. it will not.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
